Lynx Sprite Packing Tool
Cupcakus
Hey All,
I picked up a Lynx at California Extreme, and because I'm completely nuts, I can't truly enjoy a new game console, until I've written code for it, and I understand how it works.
Long story short, I was having trouble getting my head wrapped around how the sprite data has to be set up for packed sprites, so I wrote a tool to convert 16 color bitmaps into Lynx packed sprite data. Tools like this may already exist, but in any case, I thought I'd share the tool and it's source in case anyone else wants a head start, or wants to make the tool more useful. It could be better, IE: by changing the draw direction in the data it may be possible to get better compression, but I'm not figuring out the algorithm to do that :-). Depending on how many repeating pixels you have in your sprite, you can get a lot of space savings by packing your sprites up with this tool.
I used VC++ 2008, but it's all std c, so you should be able to compile it for Linux or Mac by removing the precompiled header nonsense.
lynxspr_exe.zip
lynxspr_src.zip
Edited by Cupcakus
Hey All,
there already exists sprpck in the bll package
i attached it
sprpck.zip
Yah I figured this tool already existed, I was curious to see if both tools produced the same size packed sprite or if there was a difference. However the sprpck you attached only has a cygwin.dll in it :-)
I would only give to all lynx developers the sprpck in this way
Everyone can use what he/she wants.
And thanks to post also the source - very interesting
  • 4 weeks later...
Nice alternative to sprpck as this is sometimes a bit unstable and the code not really readable.
Can you please add a Makefile for the linux people with the following content:
all: lynxspr
lynxspr: lynxspr.cpp targetver.h stdafx.h  stdafx.cpp
and wrap the #include "tchar.h" into a #if __WINDOWS(or how this is defined) / #endif as this is not needed&existing on linux.
Thanks.
So, how big is the difference?
Did you make some extensive tests?
Which one has the better packing rate in your case?
  • 2 weeks later...
I'm not sure if this was the latest and greatest version of sprpck (1.98), but 8 months ago I cleaned it up so that it would build and run on Linux: http://bitbucket.org/wookie/sprpck
Well 1.98 was the latest version (which also compiled with linux without problems afaik). At least i am using it all the time. you can find it in karri's repo in the folder newcc65.
  • 1 month later...
The results were exactly the same, which is encouraging I guess.
Interessting, in my case the "old" sprpck had a better performance. means better pack rate.
