sometimes99er Posted November 13, 2011 Share Posted November 13, 2011 (edited) Edited August 28, 2013 by sometimes99er Quote Link to comment Share on other sites More sharing options...
RXB Posted November 13, 2011 Share Posted November 13, 2011 You can write a program in XB for this controller. 10 CALL JOYST(1,X,Y) 20 CALL JOYST(2,B2,B3) 30 CALL KEY(1,B1,S) 40 CALL KEY(2,B4,S) in that 4 lines of code you get access to all the buttons on the controller. X,Y return -4,4 for up,down,let,right B1 returns 18 for button 1 B2 returns 4 for button 2 B3 returns 4 for button 3 B4 returns 18 for button 4 X,Y,B1 are normal joystick 1 functions so pad works with any single player game that supports a joystick B2,B3,B4 are calls from joystick 2 Well RXB would make that a little faster and more compact. 10 CALL JOYST(1,X,Y,2,B2,B3) 30 CALL KEY(1,B1,S,2,B4,S) As RXB stays in the orginal code and does not have to go scan a second time it is quite faster. Quote Link to comment Share on other sites More sharing options...
jchase1970 Posted November 13, 2011 Author Share Posted November 13, 2011 (edited) Paypal, jchase1970@hotmail.com but be sure to email me, or even text me at 812-459-9970. I'll be ready to send them out by Friday. In the mean time, little demo program and a crappy little video. 7 CALL CLEAR 8 CALL CHAR(42,"183C3C9999FF9981") 9 CALL SPRITE(#1,42,2,20*8,16* 10 CALL CHAR(44,"00003C42813C4218",45,"104824A4A4244810",46,"0812242525241208") 100 CALL JOYST(1,JX,JY) 110 CALL JOYST(2,B3,B2) 120 CALL KEY(1,B1,S) 130 CALL KEY(2,PAUSE,S) 140 IF PAUSE=18 THEN 1000 150 IF(JX=0)*(JY=0)THEN 160 ELSE 500 160 IF B1=18 THEN 600 170 IF B2=4 THEN 700 180 IF B3=4 THEN 800 190 IF(S1=1)+(S2=1)+(S3=1)THEN 400 200 GOTO 100 400 IF S1=1 THEN CALL POSITION(#2,Y,X)ELSE 420 410 IF Y<10 THEN CALL DELSPRITE(#2) :: S1=0 420 IF S2=1 THEN CALL POSITION(#3,Y,X)ELSE 440 430 IF X<10 THEN CALL DELSPRITE(#3) :: S2=0 440 IF S3=1 THEN CALL POSITION(#4,Y,X)ELSE 100 450 IF X>246 THEN CALL DELSPRITE(#4) :: S3=0 460 GOTO 100 500 CALL MOTION(#1,-JY,JX)::GOTO 160 600 CALL POSITION(#1,Y,X)::CALL SPRITE(#2,44,2,Y-8,X,-8,0)::S1=1::GOTO 190 700 CALL POSITION(#1,Y,X)::CALL SPRITE(#3,46,2,Y,X-8,0,-::S2=1::GOTO 180 800 CALL POSITION(#1,Y,X)::CALL SPRITE(#4,45,2,Y,X+8,0,::S3=1::GOTO 190 1000 FOR DELAY=1 TO 10 1001 NEXT DELAY 1005 CALL KEY(2,PAUSE,S) 1006 IF S=0 THEN 1005 1010 IF PAUSE=18 THEN 1020 ELSE 1005 1020 FOR DELAY=1 TO 10 1030 NEXT DELAY 1040 GOTO 100 Using 3 buttons to shoot in different directions http://youtu.be/xL45QzqjVaY John Edited November 13, 2011 by jchase1970 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 13, 2011 Share Posted November 13, 2011 You can make better video if you use http://www.hyperionics.com/ And I use http://www.freewin7software.com/ You can make pretty good videos with these and they are free. Quote Link to comment Share on other sites More sharing options...
jchase1970 Posted November 13, 2011 Author Share Posted November 13, 2011 Well RXB would make that a little faster and more compact. 10 CALL JOYST(1,X,Y,2,B2,B3) 30 CALL KEY(1,B1,S,2,B4,S) As RXB stays in the orginal code and does not have to go scan a second time it is quite faster. Wow, I like the compact way that works Just for kicks I timed it to see how much slower the extra polling was, 10 I=0 20 I=I+1 30 CALL JOYST(1,X,Y) 40 CALL KEY(1,B1,S) 50 IF I=100 THEN END 60 GOTO 20 SAME CODE WITH EXTRA POLLING INSERTED [code 35 CALL JOYST(2,B3,B2) 45 CALL KEY(2,B4,S) [/code] And the results Single poll 100 times in xb 6.4 seconds Double poll 100 times in xb 11.2 seconds It seems each call to KEY or JOYST adds about 2.5 seconds per 100, one is not faster or slower then the other, so if you dont need the pause key you can speed it up by 25% Quote Link to comment Share on other sites More sharing options...
jchase1970 Posted November 13, 2011 Author Share Posted November 13, 2011 (edited) You can make better video if you use http://www.hyperionics.com/ And I use http://www.freewin7software.com/ You can make pretty good videos with these and they are free. This was filmed on the TV using my real TI and ProPlay game pad. I use CamStudio for my screen capture video. Although I have been looking for a video converter, Thx. Edited November 13, 2011 by jchase1970 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 14, 2011 Share Posted November 14, 2011 Ok ran a test: 10 I=I+1 20 CALL JOYST(1,X,Y)::CALL JOYST(1,A,B) 30 CALL KEY(1,B1,S)::CALL KEY(2,B2,S) 40 IF i=1000 THEN END 50 GOTO 10 Result after 1 minute I=552 Next test RXB: 10 I=I+1 20 CALL JOYST(1,X,Y,2,A,B) 30 CALL KEY(1,B1,S,2,B2,S) 40 IF I=1000 THEN END 50 GOTO 10 Result after 1 minute i=597 This surprised me as I thought the difference would be greater. Making line 20 into a single CALL JOYST and CALL KEY was 545 XB and 593 for RXB. So :: actually slows the program down more then more line numbers does. Quote Link to comment Share on other sites More sharing options...
jchase1970 Posted November 14, 2011 Author Share Posted November 14, 2011 Ok ran a test: 10 I=I+1 20 CALL JOYST(1,X,Y)::CALL JOYST(1,A,B) 30 CALL KEY(1,B1,S)::CALL KEY(2,B2,S) 40 IF i=1000 THEN END 50 GOTO 10 Result after 1 minute I=552 Next test RXB: 10 I=I+1 20 CALL JOYST(1,X,Y,2,A,B) 30 CALL KEY(1,B1,S,2,B2,S) 40 IF I=1000 THEN END 50 GOTO 10 Result after 1 minute i=597 This surprised me as I thought the difference would be greater. Making line 20 into a single CALL JOYST and CALL KEY was 545 XB and 593 for RXB. So :: actually slows the program down more then more line numbers does. I'm not so surprised, as even if rxb makes it into 1 statement there are still 2 calls to the joystick. so it's not that you are really doing any less work on the machine side of the code. You can only poll one joystick x,y axis at a time and same with the buttons, you can only poll one controller button at a time. I find it so interesting how TI managed to compact the joysticks into one port by adding diodes and using the same wires to return values for 2 different joysticks. It is a impressive way to do it, all other console just use 2 joystick ports but TI did the same thing with 50% less ports. Just the fact that someone thought that out back then impresses me, "We need 2 joystick ports , wait what if we can use one port and make it do double the work? Do we need a 15 pin connecter then? No we will use the same 9 pin connector and make the 7 wires work double time too." I wonder why double command lines with the :: are slower then single line. I would think the basic interpreter would sort it out exactly the same as single command lines? Quote Link to comment Share on other sites More sharing options...
RXB Posted November 14, 2011 Share Posted November 14, 2011 (edited) Well looking over the GPL code (RXB and XB are the same here) [0303] 0082 SSEPZ EQU >82 :: <0043> CB37 82 BYTE SSEPZ * :: <0015> A000 0F,75 XML CONT XML CONT used by subprogram <0016> A002 43,FB BR LITS05 Build FAC entry and GETSTR <0017> A004 40,9C BR EXEC Execute a program <0018> A006 48,D3 BR LINE <0019> A008 48,6E BR DATAST <0020> A00A 48,8A BR ASC <0021> A00C 40,A9 BR EXEC1 <0022> A00E 41,2B BR EXEC6D Save information on a break <0023> A010 48,0A BR DELINK Delink symbol table entry <0024> A012 48,E5 BR CONV1 <0025> A014 49,C9 BR SQUISH Called in error routine in PS <0026> A016 45,71 BR VALCD <0027> A018 42,8D BR INTRND <0028> A01A 40,1A BR $ <0029> A01C 4A,E7 GA01C BR LNKRTN Routine to go back to XB prog <0072> *********************************************************** <0073> * START EXECUTION OF A PROGRAM OR STATEMENT <0074> * DATA: <0075> * RAM(START) points into line number table at the <0076> * first line to execute <0077> * @PGMFLG contains >FF if executing a program or zero <0078> * if imperative statement <0079> *********************************************************** <0080> A09C 8E,44 EXEC CZ @PRGFLG If program <0081> A09E 60,AE BS GA0AE <0082> A0A0 BD,2E,A3 DST V@START,@EXTRAM Line to start execution at A0A3 72 <0083> A0A4 95,2E DINCT @EXTRAM Pointer to text pointer <0084> A0A6 06,A2,8D CALL INTRND Initialize random number <0085> A0A9 BE,7F,03 EXEC1 ST X2,@XPT Initialize screen display <0086> A0AC 40,B2 BR GA0B2 <0087> A0AE BF,2C,08 GA0AE DST CRNBUF,@PGMPTR Executing out of crunch buffe A0B1 20 <0088> A0B2 BF,26,A0 GA0B2 DST EXEC20,@RTNG Address of return from ALC A0B5 BC <0089> A0B6 BF,28,A1 DST NUDTB,@NUDTAB NUD table address for ALC A0B9 47 <0090> A0BA 0F,76 XML EXECG Execute XB <0091> A0BC 8A,23 EXEC20 CASE @ERRCOD+1 Check type of return 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0011 EQUATES EXEC-359 <0092> A0BE 40,DF BR EXECND 0 - NORMAL END <0093> A0C0 41,1A BR EXECBK 1 - BREAKPOINT <0094> A0C2 40,ED BR EXECTR 2 - TRACE <0095> A0C4 48,AB BR ERORZ 3 - ERROR <0096> A0C6 40,D4 BR WARNGZ 4 - WARNING <0097> A0C8 41,DA BR ONERR 5 - ON ERROR <0098> A0CA 47,17 BR UDF 6 - FUNCTION <0099> A0CC 42,18 BR ONBRK 7 - ON BREAK <0100> A0CE 44,38 BR CONCAT 8 - CONCATENATE STRINGS "&" <0101> A0D0 41,AA BR ONWARN 9 - ON WARNING <0102> A0D2 42,2F BR GPLCAL A - CALL STATEMENT <0103> A0D4 C6,73,B0 WARNGZ CH >B0,@SUBSTK <0104> A0D7 6D,34 BS ERRSO <0105> * Stack overflow <0106> * ALLOW ROOM ON STACK FOR WARNING CALLS <0030> A01E 49,89 GA01E BR SPCOL Clear breakpoint in line # ro <0031> A020 46,FC BR UBSUB Spare <0032> A022 40,22 BR $ <0033> A024 40,24 BR $ *** Please let me know it you add <0034> * *** branches here since it will a <0035> * *** the address of link list. Sum So the ROMs in RXB and XB use a NUD table to find the :: or a line number and branches to the correct routine. This is the reason the :: is a little slower then Line numbers. Less parsing of the line is needed for Line numbers. (Line numbers are alway first, while :: could be anywhere.) Edited November 14, 2011 by RXB Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted December 18, 2011 Share Posted December 18, 2011 Hi Jchase ! i worte you a lot of emails for the joypad... but i had no answer... have you some news about shipping costs ? have you got and read my email ? Let me know Thankyou. Ciro Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 18, 2011 Share Posted December 18, 2011 I wonder why double command lines with the :: are slower then single line. I would think the basic interpreter would sort it out exactly the same as single command lines? This is the reason the :: is a little slower then Line numbers. Less parsing of the line is needed for Line numbers. (Line numbers are alway first, while :: could be anywhere.) So :: should be slower than line numbers ? That statement surprised me just a little bit. I think TI wrote that "multiple-statement lines" was for speed and efficiency, but then speed could then be relative to programming and not execution or something. Also I think Rich said that line numbers are looked up (to find where the next statement is), whereas :: is not (as in just continuing on the line). FOR-NEXT etc. might mess that up etc., but I thought I understood the message. My smaller (and different) test programs however show that :: is faster than line numbers. Here's one of the smaller ones ... 10 I=I+1 20 I<2000 THEN 10 30 I=1/0 10 I=I+1::I<2000 THEN 10 30 I=1/0 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 18, 2011 Share Posted December 18, 2011 (edited) Well KEY and JOYST are both mostly assembly programs and the XB PARSE routine is also a XML PARSE BYTE >B6 as a example is the >B6=( so I was comparing speed of using line numbers vs :: and using KEY and JOYST. What I showed was when the :: was added the value of variable I=I+1 was lower and indicates that it executed less times in one minute then the line numbers did. I can not explain what you did. If you make a single line 16 CALL CLEAR commands separated by :: and another program that is 16 lines with a single CALL CLEAR per line they take the same amount of time. Edited December 18, 2011 by RXB Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted December 18, 2011 Share Posted December 18, 2011 Well, I would have guessed, that it was not the fault of "::", but the double amount of CALLs, that made it slower (variable count was lower). So you're doing "only" 16 iterations of "::" versus "lines", and I guess that apparently doesn't really show any difference. I'm doing about 2000 iterations, and it's done in about 20 seconds, and then in favour of "::". Anyways, it's not important. No big deal. Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted January 5, 2012 Share Posted January 5, 2012 Hi Jchase ! i worte you a lot of emails for the joypad... but i had no answer... have you some news about shipping costs ? have you got and read my email ? Let me know Thankyou. Ciro Quote Link to comment Share on other sites More sharing options...
marc.hull Posted January 5, 2012 Share Posted January 5, 2012 Hi Jchase ! i worte you a lot of emails for the joypad... but i had no answer... have you some news about shipping costs ? have you got and read my email ? Let me know Thankyou. Ciro Ditto..... Me too please... Quote Link to comment Share on other sites More sharing options...
jchase1970 Posted January 6, 2012 Author Share Posted January 6, 2012 I got the first batch out and ran into some serious personal problems. I have some more almost done. But, I'm in the middle of moving. Please be a little patient with me and I'll contact you. Sorry, John. Quote Link to comment Share on other sites More sharing options...
marc.hull Posted January 6, 2012 Share Posted January 6, 2012 I got the first batch out and ran into some serious personal problems. I have some more almost done. But, I'm in the middle of moving. Please be a little patient with me and I'll contact you. Sorry, John. OK.... No problem. Sorry for your personal troubles, hopefully it plays out well. And don't apologize..... you are doing us a solid .... Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted March 20, 2012 Share Posted March 20, 2012 (edited) I Tried the two JoyPad i got from John Chase but i must press the direction pad very hard to be able to move a sprite on the screen... this problem make the joypads unsable. it's normal or is not normal ? i am the only one that have this problem ? i must push very strong to have the correct movements of the sprite... not for the buttons... they have a working goos as is normal... i mailed a lot of time to John but i haven't got an answer... someone could help me ? Thank You... Edited May 6, 2012 by ti99userclub Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted May 6, 2012 Share Posted May 6, 2012 have someone tried the JChase's Joypad ? Quote Link to comment Share on other sites More sharing options...
kl99 Posted December 11, 2013 Share Posted December 11, 2013 if you have an atari joystick adapter for your ti-99, you can get a very handy gamepad:http://www.ebay.com/itm/Atari-2600-Original-Atari-Joypad-Controller-Joypad-gebraucht-/390700500665?pt=DE_PC_Videospiele_Controller&hash=item5af79086b9I bought one on the last retro faire in Vienna, it works just fine with the WICO Joystick adapter. Reaction time of this Atari gamepad is really good! Could only see advantages over my other joysticks so far!TI Scramble was never so fine to play with! Quote Link to comment Share on other sites More sharing options...
