jamesk Posted December 10, 2010 Share Posted December 10, 2010 I picked up this Desoldering station. http://www.circuitspecialists.com/prod.itml/icOid/10146 It looks like the Aoyue 474A+ re-badged. This station is so good I hope to never touch the Radio Shack bulb suction again. I should have bought one of these a long time ago. I apply a bit of flux to the joint for best results. I also leave my iron on because some joints lack enough solder and it helps to have a good thick joint to suck up. I apply the end of the gun over the solder joint, with the tip touching the solder but not pushing down to touch the PCB. Once the solder melts I pull the trigger and give the joint a bit of a wiggle. Usually all the solder gets sucked up. If not I just apply some solder to the joint and get it the second time. Then I use my ESD tweezers to gently push each lead to make sure they are separated from the PCB. After that I use my extraction tool to gently lift the chip off the board. Piece of cake. Quote Link to comment Share on other sites More sharing options...
horseboy Posted December 10, 2010 Author Share Posted December 10, 2010 I picked up this Desoldering station. http://www.circuitspecialists.com/prod.itml/icOid/10146 It looks like the Aoyue 474A+ re-badged. This station is so good I hope to never touch the Radio Shack bulb suction again. I should have bought one of these a long time ago. I apply a bit of flux to the joint for best results. I also leave my iron on because some joints lack enough solder and it helps to have a good thick joint to suck up. I apply the end of the gun over the solder joint, with the tip touching the solder but not pushing down to touch the PCB. Once the solder melts I pull the trigger and give the joint a bit of a wiggle. Usually all the solder gets sucked up. If not I just apply some solder to the joint and get it the second time. Then I use my ESD tweezers to gently push each lead to make sure they are separated from the PCB. After that I use my extraction tool to gently lift the chip off the board. Piece of cake. Nice!! Quote Link to comment Share on other sites More sharing options...
