tjb Posted September 11, 2010 Share Posted September 11, 2010 The only C compilers I know of for the Atari 8-bit machines (the ones hosted on the machine itself) are: Deep Blue C originally from APX and later Antic Lightspeed C from Clearstar Softtechnologies (Apparently B & C Computervisions acquired the rights to this one at some point - I picked up a copy from them a while back) C/65 (from OSS?) I want to say there was an "Ace C" that was some derivative of Deep Blue C (or vice versa) but I can't recall for sure. Are there any others? Of those only C/65 generates native code (assembler source actually). I must admit I'm a little disappointed that the Atari 8-bits didn't have more C compilers available. It seems like the C64 had some really good native code producing compilers. I was always wondering why we didn't. Thoughts? tjb Quote Link to comment Share on other sites More sharing options...
devwebcl Posted September 11, 2010 Share Posted September 11, 2010 The only C compilers I know of for the Atari 8-bit machines (the ones hosted on the machine itself) are: Deep Blue C originally from APX and later Antic Lightspeed C from Clearstar Softtechnologies (Apparently B & C Computervisions acquired the rights to this one at some point - I picked up a copy from them a while back) C/65 (from OSS?) I want to say there was an "Ace C" that was some derivative of Deep Blue C (or vice versa) but I can't recall for sure. Are there any others? Of those only C/65 generates native code (assembler source actually). I must admit I'm a little disappointed that the Atari 8-bits didn't have more C compilers available. It seems like the C64 had some really good native code producing compilers. I was always wondering why we didn't. Thoughts? tjb Here you casn find a list of programming languages with references: http://gury.atari8.info/html_category/s_computer_languages.htm -Devwebcl Quote Link to comment Share on other sites More sharing options...
tjb Posted September 11, 2010 Author Share Posted September 11, 2010 The only C compilers I know of for the Atari 8-bit machines (the ones hosted on the machine itself) are: Deep Blue C originally from APX and later Antic Lightspeed C from Clearstar Softtechnologies (Apparently B & C Computervisions acquired the rights to this one at some point - I picked up a copy from them a while back) C/65 (from OSS?) I want to say there was an "Ace C" that was some derivative of Deep Blue C (or vice versa) but I can't recall for sure. Are there any others? Of those only C/65 generates native code (assembler source actually). I must admit I'm a little disappointed that the Atari 8-bits didn't have more C compilers available. It seems like the C64 had some really good native code producing compilers. I was always wondering why we didn't. Thoughts? tjb Here you casn find a list of programming languages with references: http://gury.atari8.i...r_languages.htm -Devwebcl Wow, that's great! Thanks! tjb Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 11, 2010 Share Posted September 11, 2010 Don't forget CC65 (the PD one) - that was distinct from C/65, wasn't it? I fancy recompiling that with a few optimisations if I can find the source code; should run fast with an HDD. Quote Link to comment Share on other sites More sharing options...
tjb Posted September 11, 2010 Author Share Posted September 11, 2010 Don't forget CC65 (the PD one) - that was distinct from C/65, wasn't it? I fancy recompiling that with a few optimisations if I can find the source code; should run fast with an HDD. That's the one from Page 6 magazine, correct? It was published with sources? Did it produce native code (directly or indirectly)? tjb Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 11, 2010 Share Posted September 11, 2010 (edited) That's the one from Page 6 magazine, correct? It was published with sources? Did it produce native code (directly or indirectly)? That's the one: ds111.zip It compiles to RA65 assembler code, then pure 6502 binary. What C compiler on the PC would be best to rebuild this? I fancy adding double-buffered I/O and such like (the I/O was single byte and way slow under SpartaDOS X with the library turned off). Edited September 11, 2010 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted September 12, 2010 Share Posted September 12, 2010 sounds like a make-work project. Why wouldn't you be cross-developing on a modern machine? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 12, 2010 Share Posted September 12, 2010 sounds like a make-work project. Why wouldn't you be cross-developing on a modern machine? I am, but I'd love to do some development on real hardware. All I ever used to use the Atari for was writing software so my current projects are kind of a means without an end. CC65 was pretty capable, just slow... Quote Link to comment Share on other sites More sharing options...
tjb Posted September 12, 2010 Author Share Posted September 12, 2010 That's the one from Page 6 magazine, correct? It was published with sources? Did it produce native code (directly or indirectly)? That's the one: ds111.zip It compiles to RA65 assembler code, then pure 6502 binary. What C compiler on the PC would be best to rebuild this? I fancy adding double-buffered I/O and such like (the I/O was single byte and way slow under SpartaDOS X with the library turned off). I was looking over the disks in the distribution and it looks like the C sources for the compiler itself are included. Is that to say that CC65 can be used to build itself? I wasn't sure what you meant when you asked which PC-based compiler would be best but now I take it you are referring to a PC-based cross-compiler to rebuild the entire suite of apps? I also noticed quite a bit of assembler source much of which I would imagine would be the RTL sources but I wonder if the initial "bootstrap" version of the compiler is included as well? tjb Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 12, 2010 Share Posted September 12, 2010 I was looking over the disks in the distribution and it looks like the C sources for the compiler itself are included. Is that to say that CC65 can be used to build itself? Yes, that's why doing some amendments is an attractive proposition. I once rather crazily attempted to use CC65 to recompile itself on a 130XE with an XF551 disk drive over a decade ago, and the experience was neither pleasant nor in any way successful! I don't believe it would be possible now, either. I wasn't sure what you meant when you asked which PC-based compiler would be best but now I take it you are referring to a PC-based cross-compiler to rebuild the entire suite of apps? I also noticed quite a bit of assembler source much of which I would imagine would be the RTL sources but I wonder if the initial "bootstrap" version of the compiler is included as well? Absolutely: I just wondered which would be the cross-compiler of choice. I think there are a few source files missing in the distribution I posted. I have the original floppies and I'm going to check through them when I get a chance. Quote Link to comment Share on other sites More sharing options...
