russg Posted October 2, 2010 Share Posted October 2, 2010 Got one of my 800s out. It booted fine. When I load a game, or even do some graphics 8 from BASIC, it hums, pretty loudly. Since the hum seems to be when graphics are being displayed, I'm thinking Antic or GTIA. I have some test modules and chips. Any ideas what may be causing the hum? If I hit Reset and exit the game to DOS, the hum quits. Quote Link to comment Share on other sites More sharing options...
atariksi Posted October 2, 2010 Share Posted October 2, 2010 Got one of my 800s out. It booted fine. When I load a game, or even do some graphics 8 from BASIC, it hums, pretty loudly. Since the hum seems to be when graphics are being displayed, I'm thinking Antic or GTIA. I have some test modules and chips. Any ideas what may be causing the hum? If I hit Reset and exit the game to DOS, the hum quits. Interference of video with audio line. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 2, 2010 Share Posted October 2, 2010 Check your TV tuning if it's via RF. POKE 77,128 and let it cycle through the colours - attract mode is good for generating weird sounds if the TV isn't tuned properly. Probably a good idea to check that the power supply isn't going bad. Check the +5V to GND on the SIO port with a multimeter - since the 800 does power conversion both in the PSU and the power supply board internally, that's 2 potential sources for overvoltage, which can potentially kill a machine. Quote Link to comment Share on other sites More sharing options...
Justin Payne Posted October 2, 2010 Share Posted October 2, 2010 Maybe it hums because it doesn't know the lyrics to the song. Sorry, I couldn't resist. ...but so message wasn't chock full of gut busting humor, I did a little Googling and I'd have to go Rybags suggestion. It appears hum can come from transformers in the power supply. The other option is trying to plug it into a different display and do the color cycle thing. Also, might also be the video switch that's plugged into the TV, but I would say the chances of this are probably slim. I'm not sure if that helps you any, but at least the joke might cheer you up a bit. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 2, 2010 Share Posted October 2, 2010 Note that "hum from power supplies" doesn't necessarily mean the hum you might get from the PS itself. Overvolting Ataris often show the symptom of unwanted audio through the TV - one I bought with a dodgy PS did it and it stopped as soon as I put it on my good supply. Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted October 2, 2010 Share Posted October 2, 2010 (edited) Have you tried passing your RF cable through a ferrite core? Edited October 2, 2010 by OldAtarian Quote Link to comment Share on other sites More sharing options...
russg Posted October 2, 2010 Author Share Posted October 2, 2010 Maybe it hums because it doesn't know the lyrics to the song. Sorry, I couldn't resist. A good one. ...but so message wasn't chock full of gut busting humor, I did a little Googling and I'd have to go Rybags suggestion. It appears hum can come from transformers in the power supply. The other option is trying to plug it into a different display and do the color cycle thing. Also, might also be the video switch that's plugged into the TV, but I would say the chances of this are probably slim. I'm not sure if that helps you any, but at least the joke might cheer you up a bit. Thanks to those who responded. The RF cable thru ferrite core. The 800 in question has a ferrite core on the RF cable inside the case. I'm using the composite monitor port. I believe I removed the RF cable on one of my 800s as it is in the way and I never use it. I made progress. I substituted the power supply/RF board and that stopped the hum. Now, I tried a burn in and after about one hour, the computer froze up, but it did pretty good just booting and playing Sargon III. I don't know what caused the crashes, probably heat related, as it takes an hour to happen. The computer should go overnight without locking up. I don't know how to service the hum power supply board. It has about four really large capacitors. I understand old capacitors can fail, and they are probably forty years old. It also has diodes of course, and a rectifier I recognize. I have two complete 800s and some extra ROM boards and a spare motherboard, I used my spare RF/PS board for this. These 800s are built like tanks. Thanks Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted October 3, 2010 Share Posted October 3, 2010 Didn't the early 800's have problems with the memory boards overheating as well, because of the cases around the boards? At least I've heard that that can also cause a similar buzzing problem. The solution was to of course remove the cases and plug the boards back in. It's unlikely to be the cause, but just another oddball suggestion. Quote Link to comment Share on other sites More sharing options...
russg Posted October 4, 2010 Author Share Posted October 4, 2010 Well, another day. I believe the crashing was a personality board problem. I tried to fix it by substituting Antic, GTIA and CPU, but that didn't work, still had crash. So, I put in a spare personality board and am going to see if it will survive overnite. Thanks for listening. I have two 800s, one is much lighter in color than the other. Did Atari make different color 800s? Quote Link to comment Share on other sites More sharing options...
atariksi Posted October 4, 2010 Share Posted October 4, 2010 Well, another day. I believe the crashing was a personality board problem. I tried to fix it by substituting Antic, GTIA and CPU, but that didn't work, still had crash. So, I put in a spare personality board and am going to see if it will survive overnite. Thanks for listening. I have two 800s, one is much lighter in color than the other. Did Atari make different color 800s? Could be more yellowing on one unit which produces sort of sun-tan look. Quote Link to comment Share on other sites More sharing options...
russg Posted October 4, 2010 Author Share Posted October 4, 2010 Well, another day. I believe the crashing was a personality board problem. I tried to fix it by substituting Antic, GTIA and CPU, but that didn't work, still had crash. So, I put in a spare personality board and am going to see if it will survive overnite. Thanks for listening. I have two 800s, one is much lighter in color than the other. Did Atari make different color 800s? It is done. Replaced the personality board and let run Pacman overnite and no lockup. Thanks everyone who responded. Quote Link to comment Share on other sites More sharing options...
