zylon Posted October 13, 2010 Share Posted October 13, 2010 Since there's been some interest in paddles for the 5200. I thought I'd share my solution. It's cheap and causes no permanent damage to the controller. I made this one using a stock cx52, the pot and knob from a Sears Arcade II controller and a paper towel. This set up avoids the "cruise control" effect on Super Breakout. 1 Quote Link to comment Share on other sites More sharing options...
Dr Manhattan Posted October 13, 2010 Share Posted October 13, 2010 Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? Quote Link to comment Share on other sites More sharing options...
zylon Posted October 13, 2010 Author Share Posted October 13, 2010 (edited) Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. Edited October 13, 2010 by zylon 1 Quote Link to comment Share on other sites More sharing options...
Dr Manhattan Posted October 13, 2010 Share Posted October 13, 2010 In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. I'm really glad you told me this. I was just about to try and create my own paddle controller. Great timing on this thread. Quote Link to comment Share on other sites More sharing options...
Big_Mo Posted October 13, 2010 Share Posted October 13, 2010 (edited) I'm interested in making something like this, but I'm not quite following what you're doing just based on the photos. Is that a POT out of a 2600 controller? Edited October 13, 2010 by Big_Mo Quote Link to comment Share on other sites More sharing options...
bohoki Posted October 13, 2010 Share Posted October 13, 2010 Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. ahh i think the adapter is using pin 12 for the pot common instead of pin 9 when you use pin 12 for the common the system thinks its using a trackball which is handy cause then you can use the keypad in pole position for shifting Quote Link to comment Share on other sites More sharing options...
zylon Posted October 13, 2010 Author Share Posted October 13, 2010 (edited) I'm interested in making something like this, but I'm not quite following what you're doing just based on the photos. Is that a POT out of a 2600 controller? You can use one of those if you want. The one I'm using is from a Sears Video Arcade II controller. They can be bought cheaply brand new still. You can either glue it to the center pivot hole in the CX52 or you can just stuff bits of paper towel around it after assembly to hold it in position. Another method would involve using a washer on top and a nut to hold a paddle pot in position. Making one of these only takes about 15 minutes. I just removed both 5200 pots and all the stick parts and used the two wires for the lower pot on the paddle one. Black on center and grey/brown on the side post. The other ones are just tucked out of the way. Edited October 13, 2010 by zylon 1 Quote Link to comment Share on other sites More sharing options...
Big_Mo Posted October 13, 2010 Share Posted October 13, 2010 I'm interested in making something like this, but I'm not quite following what you're doing just based on the photos. Is that a POT out of a 2600 controller? You can use one of those if you want. The one I'm using is from a Sears Video Arcade II controller. They can be bought cheaply brand new still. You can either glue it to the center pivot hole in the CX52 or you can just stuff bits of paper towel around it after assembly to hold it in position. Another method would involve using a washer on top and a nut to hold a paddle pot in position. Making one of these only takes about 15 minutes. I just removed both 5200 pots and all the stick parts and used the two wires for the lower pot on the paddle one. Black on center and grey/brown on the side post. The other ones are just tucked out of the way. Ah, okay! Thanks! Quote Link to comment Share on other sites More sharing options...
+Allan Posted October 13, 2010 Share Posted October 13, 2010 Just use the left and right pot from the 5200 controller. You just need to center it in the middle of the controller. I think the 2600 paddle controller knob looks the best. There are a couple of instructions on this forum to make a 5200 paddle controller out of the 5200 controller. It's pretty easy. I've done a bunch of them in the past. Allan Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted October 13, 2010 Share Posted October 13, 2010 Now if you could just figure out a way to make the stick self centering. Quote Link to comment Share on other sites More sharing options...
atariksi Posted October 13, 2010 Share Posted October 13, 2010 Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. ahh i think the adapter is using pin 12 for the pot common instead of pin 9 when you use pin 12 for the common the system thinks its using a trackball which is handy cause then you can use the keypad in pole position for shifting Yeah, Pole Position and Kaboom work fine with A2600 Paddle. Kaboom doesn't autodetect the controller type since it only supports one controller so that works great right off the bat. Pole Position detects the controller type when you start the machine so depending on Paddle position, it will think it's trackball or paddle-- so both options are available using pin 12. You can still make it stop from "cruising" in Super Breakout by turning the knob from right to center when you press the START. You'll hear that sound for a couple of seconds and at that time it's autodetecting the controller type so just turn the knob from right to center and it will treat as a Paddle instead of trackball. Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted October 13, 2010 Share Posted October 13, 2010 Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. ahh i think the adapter is using pin 12 for the pot common instead of pin 9 when you use pin 12 for the common the system thinks its using a trackball which is handy cause then you can use the keypad in pole position for shifting Yeah, Pole Position and Kaboom work fine with A2600 Paddle. Kaboom doesn't autodetect the controller type since it only supports one controller so that works great right off the bat. Pole Position detects the controller type when you start the machine so depending on Paddle position, it will think it's trackball or paddle-- so both options are available using pin 12. You can still make it stop from "cruising" in Super Breakout by turning the knob from right to center when you press the START. You'll hear that sound for a couple of seconds and at that time it's autodetecting the controller type so just turn the knob from right to center and it will treat as a Paddle instead of trackball. How in the world do you play Pole Position with a trackball? Quote Link to comment Share on other sites More sharing options...
zylon Posted October 14, 2010 Author Share Posted October 14, 2010 Now if you could just figure out a way to make the stick self centering. Best I've come up with on that so far is double rubber boots with the outer ring of the bottom one cut of so the plastic ring will seat. Quote Link to comment Share on other sites More sharing options...
Divya16 Posted October 14, 2010 Share Posted October 14, 2010 Genius! Thanks for posting those detailed pics. This set up avoids the "cruise control" effect on Super Breakout. Can you tell me a little more about this? In using another adaptor that used stock 2600 paddles, the object you control on screen keeps moving instead of stopping like it does with paddles on the 2600. For instance, you move just a little to the right but instead of stopping, the cursor keeps going right. You would have to move a little to the left to stop moving right. This effect doesn't show up on Kaboom but does on Super breakout. It has to do with auto centering or lack thereof. With the setup I'm using, both Kaboom and super breakout play exactly as intended. ahh i think the adapter is using pin 12 for the pot common instead of pin 9 when you use pin 12 for the common the system thinks its using a trackball which is handy cause then you can use the keypad in pole position for shifting Yeah, Pole Position and Kaboom work fine with A2600 Paddle. Kaboom doesn't autodetect the controller type since it only supports one controller so that works great right off the bat. Pole Position detects the controller type when you start the machine so depending on Paddle position, it will think it's trackball or paddle-- so both options are available using pin 12. You can still make it stop from "cruising" in Super Breakout by turning the knob from right to center when you press the START. You'll hear that sound for a couple of seconds and at that time it's autodetecting the controller type so just turn the knob from right to center and it will treat as a Paddle instead of trackball. How in the world do you play Pole Position with a trackball? It's auto-detecting for all the games that support trackball-- galaxian, space invaders, pole position, etc. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 15, 2010 Share Posted October 15, 2010 Here is a paddle made from a 5200 wico and a 2600 paddle. It works really well but the wico button has a bottomless feel to it that I don't care for. Still, it looks cool! I also prefer to secure the 2600 pot with a washer and nut for strength. 2 Quote Link to comment Share on other sites More sharing options...
atariksi Posted October 20, 2010 Share Posted October 20, 2010 How in the world do you play Pole Position with a trackball? It's not that good playing Pole Position with a trackball. It's better to use the Wico, PC Gravis joystick, digital joystick, or Atari 2600 paddle. Less control with the trackball in pole position. Quote Link to comment Share on other sites More sharing options...
eatenbygrues Posted October 30, 2010 Share Posted October 30, 2010 Very cool. I'm trying to build this myself as I had an old sears video arcade II controller lying around but I can't figure out how to remove the stick from the top part of the 5200 controller. I have taken the top part off, but how do you remove the rubber boot and the stick itself? Quote Link to comment Share on other sites More sharing options...
zylon Posted October 30, 2010 Author Share Posted October 30, 2010 Very cool. I'm trying to build this myself as I had an old sears video arcade II controller lying around but I can't figure out how to remove the stick from the top part of the 5200 controller. I have taken the top part off, but how do you remove the rubber boot and the stick itself? Typically, I hold the metal shaft with needlenose pliers and either twist or pry off the knob. For really stubborn ones, prying the knob upwards with a screwdriver against the pliers helps. With the knob off, all the slide plates just fall out of the controller top. The boot retaining ring can be removed from the underside with a small screwdriver through the 4 access slots. Just push in and turn to release the catches. Quote Link to comment Share on other sites More sharing options...
bohoki Posted October 30, 2010 Share Posted October 30, 2010 ya know i was thinking about the self centering problem and thought of a crazy idea what if you just took one of those springs from the bottom of a D cell flashlight you know the ones that are like a cone shaped coil and put that in theplace of the rubber boot along with a little washer on top to prevent the spring from binding in the handle jsut throwin it out there if anybody wants to give it a shot Quote Link to comment Share on other sites More sharing options...
zylon Posted October 30, 2010 Author Share Posted October 30, 2010 I'm actually trying an INTV disc spring currently. Quote Link to comment Share on other sites More sharing options...
zylon Posted April 25, 2011 Author Share Posted April 25, 2011 Giving this some bumpage since Kaboom is being played in HSC. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted April 27, 2011 Share Posted April 27, 2011 Actually a vidoe would be nice to help visualize instead of just photos. Quote Link to comment Share on other sites More sharing options...
zylon Posted April 27, 2011 Author Share Posted April 27, 2011 Actually a vidoe would be nice to help visualize instead of just photos. Don't have the technology to do so. All you need is to open controller. Remove joystick assembly from the top half. Remove the original controller pots. remove or tape up the wires that lead to the upper pot. Install the wires from the lower pot on the replacement pot of your choice. Ex: 2600 paddle pot, Sears Video Arcade II controller pots, Radio Shack pot Insert either padding, use glue, nut and washer to hold pot in position. Install rubber boot and ring with center of boot cut out to clear pot shaft. Install knob of choice. I personally, just use a crumpled up paper towel for positioning. Quote Link to comment Share on other sites More sharing options...
Dr Manhattan Posted April 27, 2011 Share Posted April 27, 2011 Atari 5200 Paddle by Dr Manhattan, on Flickr I just wanted to say that I made one of these paddles for myself. I was really surprised at how easy it was. The only thing is the POT on my 5200 paddle only had two posts and not three like the one pictured above. So I messed around a little bit and found a spot where I could sodder the second connection. I glued everything together and paddle works perfectly. It really makes playing Kaboom a lot of fun. Thanks Zylon! Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted April 27, 2011 Share Posted April 27, 2011 (edited) In the spirit of things, here is one a made many years ago. I even sold a few of these on ebay. Very easy to do yourself and I highly recommend using a washer and nut to secure the pot to the top 1/2 on the controller shell. Keep the rubber boot in place, place the knob on and it look professional. Edited April 27, 2011 by Official Ninja Quote Link to comment Share on other sites More sharing options...
