codyr783 Posted October 14, 2010 Share Posted October 14, 2010 Whenever I try to compile my game, I get a message saying "C:\...\preprocess.exe cannot start or run due to incompatibility with 64-bit versions of Windows." I've installed the .net framework and I've tried running in compatibility mode, but no luck. How can I fix this? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 14, 2010 Share Posted October 14, 2010 Did you check out the first post in the VbB thread? http://www.atariage.com/forums/topic/123849-visual-bb-1-0-a-new-ide-for-batari-basic/ If you're using Windows 7 64-bit, you'll need to update your bB files. Here is a copy of my working bB folder Quote Link to comment Share on other sites More sharing options...
codyr783 Posted October 14, 2010 Author Share Posted October 14, 2010 Now I did. Thanks Quote Link to comment Share on other sites More sharing options...
codyr783 Posted October 14, 2010 Author Share Posted October 14, 2010 One more question, when I try to compile it just says Compiling C:\...default.bas. It wont finish compiling. How do I fix this one? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 14, 2010 Share Posted October 14, 2010 (edited) One more question, when I try to compile it just says Compiling C:\...default.bas. It wont finish compiling. How do I fix this one? Did you set up everything you need to in the Settings and close VbB, then run it again? Edited October 14, 2010 by Random Terrain Quote Link to comment Share on other sites More sharing options...
codyr783 Posted October 14, 2010 Author Share Posted October 14, 2010 Yeah. Still no luck. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 14, 2010 Share Posted October 14, 2010 I don't know when jwierer will be back to this forum. He said he had to do a bit of traveling. Maybe he'll have an answer when he gets back. If I was having a problem, I'd make sure I was using the latest version of bB and VbB, and make sure I didn't have some weird permission thing with Windows screwing things up. Quote Link to comment Share on other sites More sharing options...
jwierer Posted October 14, 2010 Share Posted October 14, 2010 Yeah. Still no luck. I'd first try compiling at the command line and comfirm that bB is actually working first. -Jeff Quote Link to comment Share on other sites More sharing options...
