ACML Posted October 19, 2010 Share Posted October 19, 2010 I have a broken pin 2 (CLK OUT) on an SIO port. If I cut the lead from the back side (mobo) can you pull the remaining piece through the black plastic case or do I have to dremel it out with a small drill bit? I plan to use a paperclip or sewing needle to replace the missing pin. Any tips or tricks? Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted October 19, 2010 Share Posted October 19, 2010 I have a broken pin 2 (CLK OUT) on an SIO port. If I cut the lead from the back side (mobo) can you pull the remaining piece through the black plastic case or do I have to dremel it out with a small drill bit? I plan to use a paperclip or sewing needle to replace the missing pin. Any tips or tricks? They just slide out so you could cut the lead and pull it out. Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 19, 2010 Share Posted October 19, 2010 You could probably get away without having it for a while. APE and 1050s at the least shouldn't need it. Quote Link to comment Share on other sites More sharing options...
ACML Posted October 20, 2010 Author Share Posted October 20, 2010 I want to use an SIO2USB. Are you saying that it won't need pin 2? Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted October 20, 2010 Share Posted October 20, 2010 (edited) I have the USB2SIO and counted the pins at the SIO plug and pin2 was one of the pins 3,4,5,7,10. If I counted it correctly. Edited October 20, 2010 by rdea6 Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 20, 2010 Share Posted October 20, 2010 Clock is used by peripheral makers if they "feel the need" to use it. In the cases of 1050 and SIO2PC/APE at the least, there is no need. So long as a peripheral can keep it's timing within +- 5% or so of what Pokey is using, then you don't get problems. You could probably work out what peripherals (if any) use the Clock by checking out the schematics. Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted October 21, 2010 Share Posted October 21, 2010 I have a broken pin 2 (CLK OUT) on an SIO port. If I cut the lead from the back side (mobo) can you pull the remaining piece through the black plastic case or do I have to dremel it out with a small drill bit? I plan to use a paperclip or sewing needle to replace the missing pin. Any tips or tricks? I have replaced a broken pin with same size copper wire. Will work but copper will tarnish after a while. Try your best to round off the end of the wire. Pin 2 isn't used by any atari device that I know of. Most if not all 3rd party floppy drives don't make use of clock out either.Some of the newer 3rd party devices may use clock out. Best to try and see if sio2usb works before trying to fix the sio port. James Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 21, 2010 Share Posted October 21, 2010 Buy some nasty old broken Atari peripheral (except a 410 and the like) cheap and remove the SIO ports for spares. Then keep the broken ones if you want to try replacing individual pins in the future. Quote Link to comment Share on other sites More sharing options...
sloopy Posted October 21, 2010 Share Posted October 21, 2010 Buy some nasty old broken Atari peripheral (except a 410 and the like) cheap and remove the SIO ports for spares. Then keep the broken ones if you want to try replacing individual pins in the future. there is no such thing as a nasty atari peripheral ;') but for this a 1027 printer would be a good choice, as they are dirt cheap (cause they are useless, since all the print heads have turned into something that resembles severely overcooked pasta), have two sio ports, and a host of other cool little parts... sloopy. 1 Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 21, 2010 Share Posted October 21, 2010 there is no such thing as a nasty atari peripheral ;') I've gotten peripherals so dirty I put the plastic parts in the bathtub with me. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted October 21, 2010 Share Posted October 21, 2010 there is no such thing as a nasty atari peripheral ;') I've gotten peripherals so dirty I put the plastic parts in the bathtub with me. WITH you... now that's just creepy! Quote Link to comment Share on other sites More sharing options...
Bryan Posted October 21, 2010 Share Posted October 21, 2010 (edited) WITH you... now that's just creepy! Yep, I get out of the tub smelling like old computer equipment. Actually, I was cleaning stuff that was so grungy I knew I'd end up soaked either way. Edited October 21, 2010 by Bryan Quote Link to comment Share on other sites More sharing options...
Almost Rice Posted October 21, 2010 Share Posted October 21, 2010 I have pulled out the remnants of the broken pin in a 400 I had. I then cut a paper clip and bent it into shape. I replaced the pin with the cut paperclip and soldered into place. It looks good and tested fine, but I did not keep it long enough to test if it held up or if the connection had any problems. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted October 21, 2010 Share Posted October 21, 2010 I've had so much broken equipment pass through my hands that I have a supply of spare sockets for these events. Knock on wood I've only had to use one so far. Quote Link to comment Share on other sites More sharing options...
