SlowCoder Posted October 22, 2010 Share Posted October 22, 2010 I just received the expansion #1. I play with it for a while, and do like it! I would like to know if there is a way to play my CV games without first removing the expansion from the CV? Quote Link to comment Share on other sites More sharing options...
+5-11under Posted October 22, 2010 Share Posted October 22, 2010 Here's some info: http://www.atariage.com/forums/topic/149407-colecovision-atari-module-switch/page__fromsearch__1 As mentioned, I haven't tried it... I just used masking tape to test it out. 5-11under Quote Link to comment Share on other sites More sharing options...
youki Posted October 22, 2010 Share Posted October 22, 2010 I'm pretty sure that back in time i have never unplugged my Expension Module to play my coleco games.???? (on French secam colecovision) Quote Link to comment Share on other sites More sharing options...
+5-11under Posted October 22, 2010 Share Posted October 22, 2010 I can't actually remember, since I use the expansion module mostly to test video mods. Maybe my post above relates to having two cartridges inserted at the same time? Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted October 22, 2010 Author Share Posted October 22, 2010 Maybe my post above relates to having two cartridges inserted at the same time? I've tried it with and without the Atari cartridge installed. It defaults to Atari when the cartridge is inserted. Without the Atari cartridge inserted, I get a black screen, whether or not a CV cartridge is inserted. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted October 22, 2010 Share Posted October 22, 2010 Maybe my post above relates to having two cartridges inserted at the same time? I've tried it with and without the Atari cartridge installed. It defaults to Atari when the cartridge is inserted. Without the Atari cartridge inserted, I get a black screen, whether or not a CV cartridge is inserted. This is consistent with what I would expect, personally. The ColecoVision's CPU is overriden by the CPU in the expansion module, which litterally takes over the CV and simply uses its video and audio output. So in other words, when the expansion module is plugged in, the CV becomes an Atari 2600, for all intents and purposes. Turn the machine on without an Atari 2600 in the cartridge slot, and it will react just like an actual Atari 2600: It will display a blank screen. Quote Link to comment Share on other sites More sharing options...
+Yurkie Posted October 22, 2010 Share Posted October 22, 2010 The worst part about unplugging it, is that the expansion door gets stuck in the up position. This problem can be eliminated by cutting the little nub off the top of the expansion module door. I have did this on several console when refurbishing and modding them. Quote Link to comment Share on other sites More sharing options...
youki Posted October 22, 2010 Share Posted October 22, 2010 I wonder if on my Expansion module they was a power on/of button. (not a hack) I will check on the ones i have in my collections. Quote Link to comment Share on other sites More sharing options...
