NickH93 Posted October 26, 2010 Share Posted October 26, 2010 Hey everyone. I decided to pull out my TI99/4A for fun. I decided i wanted to make a cassette cable out of an old 9-pin connector and audio jack. http://pinouts.ru/Storage/cassette_ti_99_4a_pinout.shtml According to this pinout, the only inward signals are 8 and 9, Input from tape 1 and 2, and dito (please explain that dito). If i just want to load tapes, thats it, what other pins would i need? Besides 8 and 9, and what is "dito"? Sorry if I sound like an amateur, but I'm relatively new to making cables...any help? Thanks, Nick Quote Link to comment Share on other sites More sharing options...
NickH93 Posted October 26, 2010 Author Share Posted October 26, 2010 Seems like i have it working, other than the fact that the audio levels are very low. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 9, 2010 Share Posted November 9, 2010 Seems like i have it working, other than the fact that the audio levels are very low. "Ditto" means "the same," in this context, for instance, pins 1 and 2 are for CS1 motor control, but you see in the comments that pin 2 is the "negative" return. As for audio levels, you will have to experiment with the volume and tone controls on the playback device. They make a HUGE difference. The pinout page is not entirely accurate in that "cassette 1 can't be written to." CS1 can save and load, while CS2 can only save. The 99ers.net pinout page has the exact same information. Quote Link to comment Share on other sites More sharing options...
NickH93 Posted November 11, 2010 Author Share Posted November 11, 2010 Seems like i have it working, other than the fact that the audio levels are very low. "Ditto" means "the same," in this context, for instance, pins 1 and 2 are for CS1 motor control, but you see in the comments that pin 2 is the "negative" return. As for audio levels, you will have to experiment with the volume and tone controls on the playback device. They make a HUGE difference. The pinout page is not entirely accurate in that "cassette 1 can't be written to." CS1 can save and load, while CS2 can only save. The 99ers.net pinout page has the exact same information. Since I posted that, I fixed it, and had Tunnels of doom load successfully. If you know, could you tell mer what "audio gate" is? Quote Link to comment Share on other sites More sharing options...
craftsman1234 Posted May 10, 2016 Share Posted May 10, 2016 Reviving a bit of an old thread. I was able to pick up a TI-99 4/a this weekend and it runs great. I was able to get a composite cable for it. Now I need to make a tape cable. The pin-out also has me confused. It looks like I need 8&9 for input. 1 & 2 Motor Control And I have no idea for output to save. Help Thanks. Quote Link to comment Share on other sites More sharing options...
jdgabbard Posted May 11, 2016 Share Posted May 11, 2016 Now, I've never made a cassette cable for a TI-99/4A, but I have made cables for other computers. It appears that for a single cassette you'll need the following connections: Pins 6&7 are the motor control pins, pin 3 is Mic, pin 8 is the audio in (headphone), and pin 9 is a ground. The ground for Mic and headphone would likely be tied together. I'm not sure what pin 4 does. So if it were me, I would wire my cable like this and test Mic -> 3&9 HPs -> 8&9 Motor -> 6&7 But without my TI handy to do some probing, this is a best guess. Quote Link to comment Share on other sites More sharing options...
