José Pereira Posted November 12, 2010 Share Posted November 12, 2010 Hi, just want to know how cycles are in 160resol. Bitmap Screen arranjed on the 240 Lines: -> 1pixel high and -> 2pixels high (like Zybex, Draconus,...) in 32, 40 and 48wide Modes? (just Screen without DLIs, nor any other thing) Thanks. José Pereira. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 12, 2010 Share Posted November 12, 2010 The PDF with the Altirra package should have all that info, it's a good reference. For the 160 modes - 9 Refresh cycles lost every scanline. 1 DList cycle every scanline (or 2 for Gr. 7 mode), or 3 if it's an LMS instruction. Gr. 15 screens will have at least 2 LMS instructions 1 DMA cycle lost for each byte, so 40 per scanline in higher res. In the lores (Gr. 7) multicolour, each second scanline has only the Refresh cycles to worry about. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 12, 2010 Share Posted November 12, 2010 The PDF with the Altirra package should have all that info, it's a good reference. Thanks for pointing that out Rybags: I'd missed it before. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 12, 2010 Share Posted November 12, 2010 The PDF with the Altirra package should have all that info, it's a good reference. I'll second that! It's a great source of information. Quote Link to comment Share on other sites More sharing options...
José Pereira Posted November 16, 2010 Author Share Posted November 16, 2010 (edited) The PDF with the Altirra package should have all that info, it's a good reference. For the 160 modes - 9 Refresh cycles lost every scanline. 1 DList cycle every scanline (or 2 for Gr. 7 mode), or 3 if it's an LMS instruction. Gr. 15 screens will have at least 2 LMS instructions 1 DMA cycle lost for each byte, so 40 per scanline in higher res. In the lores (Gr. 7) multicolour, each second scanline has only the Refresh cycles to worry about. Sorry returning to this one, but this I couldn't undertsand there: FIRST: How many free cycles to use in an all Screen hhigh 48x15CharLines ANTIC5 Screen? SECOND: How many cycles in a 48Widex15CharLines cost in ANTIC5? Each Line it's 2pixels high, soo what I have? CHARLINE=16scanlines Each A8Line=2Scanlines. 1st Scanline: 1_refresh+1_CharsetDLI+48_Charset+48_Chars 2nd " : 9_refresh cycles+1_CharsetDLI 3rd " : 9_refresh+48_Chars 4th " : 9_refresh 5,7,9,11,13and15 like 3th scanline 6,8,10,12,14and16 like 4th.com scanline. ???? Thanks. José Pereira. Edited November 16, 2010 by José Pereira Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 16, 2010 Share Posted November 16, 2010 48 byte modes are variable depending on what HSCROL value is in use - can be less if HSCROL is a higher value. The Altirra docs has good info there. Quote Link to comment Share on other sites More sharing options...
