jp48 Posted November 15, 2010 Share Posted November 15, 2010 Hi all, Trying to write CC65-program to Lynx, using only Mikey audio, writing directly to sound registers using POKE (have done same for several consoles, without problems, or at least problems I couldn't solve myself . Anyway when trying to do same for Lynx, nothing (except interesting graphics in Handy), using POKE to write 0xFD20 to 0xFD27, apparently something is needed to initialize Mikey/Lynx/audio, I've only used CLI(), should I initialize tgi too. And/or anything else ? Thanks for advance ! -jp Quote Link to comment Share on other sites More sharing options...
matashen Posted November 15, 2010 Share Posted November 15, 2010 Hi all, Trying to write CC65-program to Lynx, using only Mikey audio, writing directly to sound registers using POKE (have done same for several consoles, without problems, or at least problems I couldn't solve myself . Anyway when trying to do same for Lynx, nothing (except interesting graphics in Handy), using POKE to write 0xFD20 to 0xFD27, apparently something is needed to initialize Mikey/Lynx/audio, I've only used CLI(), should I initialize tgi too. And/or anything else ? Thanks for advance ! -jp no, there is no more to initialize here are a example how to get out some noise... uchar MStereo at 0xfd50; #define Channel0 (char *)0xfd20 #define Channel1 (char *)0xfd28 #define Channel2 (char *)0xfd30 #define Channel3 (char *)0xfd38 void SoundInit() { MStereo = 0x42; } void SoundSetup(channel, volume, shift, lowshift, backup, flags) uchar *channel; uchar volume; uchar shift; uchar lowshift; uchar backup; uchar flags; { channel[0] = volume; channel[1] = shift; channel[3] = lowshift; channel[4] = backup; channel[5] = flags; } SoundSetup(Channel3,0x00,0x00,0x05,0xbb,0x19); I use it with the newcc65 from the BLL Kit and it runs Regards Matthias Quote Link to comment Share on other sites More sharing options...
jp48 Posted November 15, 2010 Author Share Posted November 15, 2010 no, there is no more to initialize here are a example how to get out some noise... uchar MStereo at 0xfd50; #define Channel0 (char *)0xfd20 #define Channel1 (char *)0xfd28 #define Channel2 (char *)0xfd30 #define Channel3 (char *)0xfd38 void SoundInit() { MStereo = 0x42; } void SoundSetup(channel, volume, shift, lowshift, backup, flags) uchar *channel; uchar volume; uchar shift; uchar lowshift; uchar backup; uchar flags; { channel[0] = volume; channel[1] = shift; channel[3] = lowshift; channel[4] = backup; channel[5] = flags; } SoundSetup(Channel3,0x00,0x00,0x05,0xbb,0x19); I use it with the newcc65 from the BLL Kit and it runs Regards Matthias Thanks very much Matthias, yes, I only poked to 0xfd50 as "init" and it works ! Only thing I can't find (or perhaps the mechanism is different) is vblank routine for timing. nes.h contains waitvblank(), anything similar to Lynx. Has anyone used mednafen as Lynx emulator, I can't get it work (except with NES, nothing else), lynxboot.img is copied and has correct MD5 sum, anyway doesn't recognize Lynx .o files. Any of them, not only mine . Thanks ! -jp Quote Link to comment Share on other sites More sharing options...
matashen Posted November 16, 2010 Share Posted November 16, 2010 no, there is no more to initialize here are a example how to get out some noise... uchar MStereo at 0xfd50; #define Channel0 (char *)0xfd20 #define Channel1 (char *)0xfd28 #define Channel2 (char *)0xfd30 #define Channel3 (char *)0xfd38 void SoundInit() { MStereo = 0x42; } void SoundSetup(channel, volume, shift, lowshift, backup, flags) uchar *channel; uchar volume; uchar shift; uchar lowshift; uchar backup; uchar flags; { channel[0] = volume; channel[1] = shift; channel[3] = lowshift; channel[4] = backup; channel[5] = flags; } SoundSetup(Channel3,0x00,0x00,0x05,0xbb,0x19); I use it with the newcc65 from the BLL Kit and it runs Regards Matthias Thanks very much Matthias, yes, I only poked to 0xfd50 as "init" and it works ! Only thing I can't find (or perhaps the mechanism is different) is vblank routine for timing. nes.h contains waitvblank(), anything similar to Lynx. Has anyone used mednafen as Lynx emulator, I can't get it work (except with NES, nothing else), lynxboot.img is copied and has correct MD5 sum, anyway doesn't recognize Lynx .o files. Any of them, not only mine . Thanks ! -jp Timing by Vsync extern uchar VBLflag; #asm _VBLflag = $a0 #endasm #define VSYNC {++VBLflag;while( VBLflag );} VBL() interrupt { char i; VBLflag = 0; // indicates that a VBL has ocurred lastcounter++; } .... main() { ... InitIRQ(); InstallIRQ(2,VBL); EnableIRQ(2); CLI; ... } Regards Matthias Quote Link to comment Share on other sites More sharing options...
sage Posted January 2, 2011 Share Posted January 2, 2011 Thanks very much Matthias, yes, I only poked to 0xfd50 as "init" and it works ! Only thing I can't find (or perhaps the mechanism is different) is vblank routine for timing. nes.h contains waitvblank(), anything similar to Lynx. Has anyone used mednafen as Lynx emulator, I can't get it work (except with NES, nothing else), lynxboot.img is copied and has correct MD5 sum, anyway doesn't recognize Lynx .o files. Any of them, not only mine . Thanks ! -jp mednafen does not recognize *.o files, you have to convert them to an rom image and then to a handy lnx format image. Thats why I only use Makefiles for development nowadays, it doesnt matter if i only create a .o or the complete image. everthign goes in one step. OR you add the support to mednafen :-) Quote Link to comment Share on other sites More sharing options...
+karri Posted January 3, 2011 Share Posted January 3, 2011 (edited) mednafen does not recognize *.o files, you have to convert them to an rom image and then to a handy lnx format image. Thats why I only use Makefiles for development nowadays, it doesnt matter if i only create a .o or the complete image. everthign goes in one step. OR you add the support to mednafen :-) That is the main reason why I added the .lnx target generation as the default target to the cc65.org tools. The new cc65 tools set up the IRQ's automatically. You do not need to set up any vectors anymore. Instead you have to declare your ASM routine to be an interrupt handler like this; .interruptor RealTimeHandler .export _lastcounter _lastcounter .word 0 RealTimeHandler: lda INTSET and #VBL_INTERRUPT beq @1 inc _lastcounter bne @1 inc _lastcounter+1 @1: clc rts The linker will take care of creating the vectors and setting up everything. This handler will then be called at every interrupt. It will then check if the interrupt was generated by VBL and if it was it increments _lastcounter. To activate the interrupt you can initialize the tgi-driver (it is automatically setting up the VBL counter, interrupt handlers and vectors). tgi_install(&lynxtgi); tgi_init(); CLI(); All interruptors will always be called during every interrupt as long as carry is cleared when the interruptor exits. If you set the carry flag before exit then the interrupt has been handled. In my interruptors (tgi-graphics and ComLynx) I always leave the carry as cleared so that you can add your own hooks for some extra processing. This is why you can have many interruptors that share the same interrupt. Like tgi-processing and incrementing _lastcounter. Both handlers will be called. Or you can even set up an interruptor of your own for the music. It should be something similar to the VBL interrupts. From the asminc file it appears that interrupts 0, 2 and 4 are taken. ; Interrupt bits in INTRST and INTSET TIMER0_INTERRUPT = $01 TIMER1_INTERRUPT = $02 TIMER2_INTERRUPT = $04 TIMER3_INTERRUPT = $08 TIMER4_INTERRUPT = $10 TIMER5_INTERRUPT = $20 TIMER6_INTERRUPT = $40 TIMER7_INTERRUPT = $80 HBL_INTERRUPT = TIMER0_INTERRUPT VBL_INTERRUPT = TIMER2_INTERRUPT SERIAL_INTERRUPT = TIMER4_INTERRUPT lda #$80 ; Enable VBL interrupts tsb VTIMCTLA lda #$7e ; 75 Hz ldx #$20 sta HTIMBKUP stx PBKUP -- Regards, Karri Edited January 3, 2011 by karri Quote Link to comment Share on other sites More sharing options...
