godzillajoe Posted November 16, 2010 Share Posted November 16, 2010 I haven't pulled anything apart yet. How does it look inside? Is there soldering involved. It's not any special type of cable is it? Quote Link to comment Share on other sites More sharing options...
zylon Posted November 16, 2010 Share Posted November 16, 2010 Yes. It's soldered in place. It's just heavily shielded coax cable with clamp on the inside end. Quote Link to comment Share on other sites More sharing options...
+madman Posted November 16, 2010 Share Posted November 16, 2010 I haven't pulled anything apart yet. How does it look inside? Is there soldering involved. It's not any special type of cable is it? It is replaceable and it is soldered to the board. Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted November 17, 2010 Author Share Posted November 17, 2010 Thanks. I'll have to open it up or just try my dupe system which may not work. I foregt. This one seems to be a bit wonky in that if you move the cable, the system shuts off. Something is loose somewhere. Quote Link to comment Share on other sites More sharing options...
OldAtarian Posted November 17, 2010 Share Posted November 17, 2010 Is the cable from the 4 port the same as the one as the one on the two port? I would think the 4 port one would be different since it also has to carry power in addition to the RF and keep the two separated. Quote Link to comment Share on other sites More sharing options...
zylon Posted November 17, 2010 Share Posted November 17, 2010 Thanks. I'll have to open it up or just try my dupe system which may not work. I foregt. This one seems to be a bit wonky in that if you move the cable, the system shuts off. Something is loose somewhere. Mine did that. What I did was open the switchbox and bent the bottom of the center contact so it would contact the plug more securely. No problems since. Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted November 17, 2010 Author Share Posted November 17, 2010 (edited) I busted it open and it looks like the solder to one of the pins to the coax in is cracked. The socket kinda wobbles around. One drop of solder and should be good as new I assume. Bottom right corner Edited November 17, 2010 by godzillajoe Quote Link to comment Share on other sites More sharing options...
zylon Posted November 17, 2010 Share Posted November 17, 2010 A cracked solder joint will do that as well. I turn off the light while moving the cable around to check for intermittent breaks in the connection. They'll spark if you have one. (not counting the one you get when plugging the cord in) Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted November 20, 2010 Author Share Posted November 20, 2010 A drop of solder to keep things from jiggling around and it's good as new Quote Link to comment Share on other sites More sharing options...
+madman Posted November 20, 2010 Share Posted November 20, 2010 Now there's a TV fit for playing the 5200! Quote Link to comment Share on other sites More sharing options...
godzillajoe Posted November 21, 2010 Author Share Posted November 21, 2010 (edited) Now there's a TV fit for playing the 5200! Ha. Quality wood grain paneling and no remote! Years ago when I was living in a big apt. in Boston. Someone left it in the trash room with a sign that said "works but is ugly" I grabbed it and kept it in a spare room or when I bought a house out on the screened in porch. Decided the other day to bring it upstairs and hook all my game systems up to it. I call it the "retro room" Decorated with all my old band posters from HS and college. Genesis, Marillion, Kate Bush.... Edited November 21, 2010 by godzillajoe Quote Link to comment Share on other sites More sharing options...
Greg2600 Posted November 21, 2010 Share Posted November 21, 2010 Is the cable from the 4 port the same as the one as the one on the two port? I would think the 4 port one would be different since it also has to carry power in addition to the RF and keep the two separated. Must be, because my 2-port cable is a simple RF that is detachable, like the 2600. Quote Link to comment Share on other sites More sharing options...
