Ran out of bits. Maybe I can grab a bit 7?
I found out that I need one more bit, but I used all of the ones I had available. If I can find a variable that doesn't go anywhere near 128, can I use bit 7 without any problems?
Edit:
I should probably mention that I know I'll have to ignore that bit. Would it make adding and subtracting a pain? Below is my guess.
If I want to know the value of a, I'd do this:
temp5 = a & %01111111
But I should be able to add and subtract the normal way as long as I don't go below 0 or over 127, right?
Edited by Random Terrain
https://forums.atariage.com/topic/173128-ran-out-of-bits-maybe-i-can-grab-a-bit-7/
I tried it and it seems to be working fine. Unless there is a hidden problem I don't know about, this looks like a good way to grab some free bits without screwing things up.
