Heaven/TQA Posted December 25, 2010 Share Posted December 25, 2010 when I am using a fullscreen (240 scanlines) antic e screen where normal 40 byte mode, where should the screen ram start to avoid the "4k boundary" issue? ($6140, $6010 the standard ones are working in 48 byte mode) Quote Link to comment Share on other sites More sharing options...
analmux Posted December 25, 2010 Share Posted December 25, 2010 You cannot avoid it without a second LMS and reprogramming the screen driver you're using: 240 scanlines * 40 bytes (per scanline) = 9600 bytes = 2*4096+1408 bytes. Thus, it uses (parts of) at least 3 blocks of 4kB, so there's at least 2 boundaries of 4kB. The middle one of the 3 blocks is always used. This can't be divided into an integer number of 40 byte blocks...etc. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 25, 2010 Author Share Posted December 25, 2010 You cannot avoid it without a second LMS and reprogramming the screen driver you're using: 240 scanlines * 40 bytes (per scanline) = 9600 bytes = 2*4096+1408 bytes. Thus, it uses (parts of) at least 3 blocks of 4kB, so there's at least 2 boundaries of 4kB. The middle one of the 3 blocks is always used. This can't be divided into an integer number of 40 byte blocks...etc. Well forgotten to say that i am using each scanline an lms command. And it Works with $6020 f.e. Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 26, 2010 Share Posted December 26, 2010 You could use LMS and skip 64 bytes per scanline, but that's a bit wasteful even in Wide (48 byte) mode that's 3840 bytes not being used. Easier way might be to just use table-lookup when addressing the screen RAM, then you can put the skipped screen RAM wherever you want (obviously has to be part of the middle 4K chunk being used). Quote Link to comment Share on other sites More sharing options...
MaPa Posted December 26, 2010 Share Posted December 26, 2010 Simply you can't have continuous video ram if you have 40 bytes screen width and >8kb video ram. Quote Link to comment Share on other sites More sharing options...
