Cynicaster Posted December 26, 2010 Share Posted December 26, 2010 My sister picked up a used 7800 and it works great except for the reset button. As it turns out, this doesn't really matter much for a lot of 7800 games because they can be started with the joystick buttons, but it's obviously a problem when trying to play a lot of 2600 titles. I opened the case to have a look, and it almost looks like somebody spilled something on this thing, because there is some staining on the board. Anyway, I verified by pressing directly on the switch that it doesn't work. It's soldered to the board at 4 points. Anybody have any suggestions about what I should do? I figured that if the switch itself is ruined, worst case scenario is I could go to Radio Shack and pick up a momentary switch, drill a hole in the case, and install a new button. I'd prefer it not come to that, though. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted December 26, 2010 Share Posted December 26, 2010 Fortunately, you can still get replacement switches that are an exact match for the ones Atari used in the 7800; just desolder the old one, solder in the new one, and it should be as good as new. Here is the correct part number from Mouser Electronics. They're so inexpensive that it might not be a bad idea to pick up several, just to keep as spares. 1 Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted December 26, 2010 Share Posted December 26, 2010 You might try spraying some electronic cleaner (available at auto parts stores) into the switch before replacing it, especially if you suspect something was spilled inside. Might also try De-Oxit if you have it. Quote Link to comment Share on other sites More sharing options...
Chuplayer Posted December 28, 2010 Share Posted December 28, 2010 Fortunately, you can still get replacement switches that are an exact match for the ones Atari used in the 7800; just desolder the old one, solder in the new one, and it should be as good as new. Here is the correct part number from Mouser Electronics. They're so inexpensive that it might not be a bad idea to pick up several, just to keep as spares. Is there a list of part numbers and whatnot and places to get them for all the Atari 7800 parts? I'd love to replace all of the switches on my 7800 if I could. Specifically the maintained power switch. Quote Link to comment Share on other sites More sharing options...
tz101 Posted December 29, 2010 Share Posted December 29, 2010 Fortunately, you can still get replacement switches that are an exact match for the ones Atari used in the 7800; just desolder the old one, solder in the new one, and it should be as good as new. Here is the correct part number from Mouser Electronics. They're so inexpensive that it might not be a bad idea to pick up several, just to keep as spares. Do those also work for the 7800 power-on switch? Mine is spotty as far as working only part of the time. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 29, 2010 Share Posted December 29, 2010 Yes, all four of the main 7800 console buttons (Power, Pause, Select and Reset) use the same type of switch. Mitch 1 Quote Link to comment Share on other sites More sharing options...
zylon Posted December 31, 2010 Share Posted December 31, 2010 Another item you can use is paddle fire button switches. Requires trimming the peg on bottom of console button though. Quote Link to comment Share on other sites More sharing options...
Chuplayer Posted December 31, 2010 Share Posted December 31, 2010 Yes, all four of the main 7800 console buttons (Power, Pause, Select and Reset) use the same type of switch. Mitch Even the power switch? That one's not a maintained switch? Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 31, 2010 Share Posted December 31, 2010 Yes, all four of the main 7800 console buttons (Power, Pause, Select and Reset) use the same type of switch. Mitch Even the power switch? That one's not a maintained switch? Yes, the power switch is identical to the other three. Mitch Quote Link to comment Share on other sites More sharing options...
Chuplayer Posted December 31, 2010 Share Posted December 31, 2010 Yes, all four of the main 7800 console buttons (Power, Pause, Select and Reset) use the same type of switch. Mitch Even the power switch? That one's not a maintained switch? Yes, the power switch is identical to the other three. Mitch Sweet. Thanks. Quote Link to comment Share on other sites More sharing options...
