JonnyBritish Posted January 30, 2011 Share Posted January 30, 2011 The manual at Atarimania is a low DPI scan but played around with a few samples showing how to manipulate PMG's etc. Also added a short video showing result. You can also use shapes per PMG to also do animation in a PMG. Here is the code for this sample ( PM-Graphics Demo # 2 ) Forth Definitions Decimal : Task ; : PDAT 1 2 3 4 5 5 ; : MDAT 1 2 1 2 1 5 ; : Demo2 4 0 Do PDAT I PLOAD MDAT I MLOAD I 120 120 PPLOT I 120 120 MPLOT I I 3 * 4 PCOL LOOP BEGIN 4 0 DO I 2 I PMOVE I 2 I 4 + MMOVE LOOP ?TERMINAL UNTIL ; 1 GRAPHICS 1 PM-GRAPHICS DEMO2 Anyone have a better scan of the ES Forth manual or more information - did you ever use it? ESFORTH.zip Quote Link to comment Share on other sites More sharing options...
Sub(Function(:)) Posted January 30, 2011 Share Posted January 30, 2011 I have not seen a good copy of the documentation. Sorry this is a bit off topic, but is there any reason you want to use ES forth? Have a look at the forth section on Carsten's Wiki. He has a selection of more "Modern", and better documented, forth version for the 8bit. X-forth and Volks Forth are good options Quote Link to comment Share on other sites More sharing options...
