Tickled_Pink Posted February 16, 2011 Share Posted February 16, 2011 I picked up a faulty Xbox off eBay to fix. The rrod problem was mentioned, but not the faulty eject button. When it got to me, it worked for a while and I was able to test the drive. It's fine. I could eject the drive from the control panel. It's just the button. However, now the rrod is flashing away I can't retrieve the error code. Is there a way of doing it when I can't use the eject button. And it is the physical button that's knackered, not the plastic button on the front. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted February 17, 2011 Share Posted February 17, 2011 Possibly... I think there's a wire you can short in the drive's power cable that controls the disc tray. What're you talking about with retrieving an error code with the eject button, though? Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 17, 2011 Share Posted February 17, 2011 If you take out the motherboard, you can see that the button is just a simple switch. You can combine the two pins on the bottom of the motherboard, where the switch is, for that code. Quote Link to comment Share on other sites More sharing options...
Tickled_Pink Posted February 17, 2011 Author Share Posted February 17, 2011 Possibly... I think there's a wire you can short in the drive's power cable that controls the disc tray. What're you talking about with retrieving an error code with the eject button, though? I'm talking about this: It just helps you identify the cause of a RROD. But I'll probably just try a reflow on the GPU. Quote Link to comment Share on other sites More sharing options...
