Marius Posted February 23, 2011 Share Posted February 23, 2011 Hi! Is there a way of switching the Arrow Keys off? I am writing a routine with some input fields. I don't want that the user can WALK over the screen with the cursor. The only thing I can think of is check ROWCRS ($54) and COLCRS ($55, $56) all the time, and reset those registers when someone walks out of the range. Break can be switched off by disableng the IRQ for that. Is there such a solution for the ARROW keys too? Thanks M. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 23, 2011 Share Posted February 23, 2011 There's a few things you could do: 1. On the XL/XE only, the keyboard definition table can be user-provided in RAM, so you could have an alternate map without cursor movement. 2. DIY keyboard IRQ routine that masks out cursor keys. 3. Easiest way - just use K: for input instead of E:, mask out the keys you don't want, then echo input to E: Advantage there is you could also put a limit on input field size, disadvantage is you still need to handle Backspace, and you'd need to read the input off the screen once the user presses Return. Problem with 1 & 2 is with cursor keys disabled you can still get runaway conditions e.g. where the user just enters hundreds of characters worth of input, but of course E: will never return more than 3 screen lines worth of data. 1 Quote Link to comment Share on other sites More sharing options...
Marius Posted February 23, 2011 Author Share Posted February 23, 2011 @Rybags Wow. Thanks for your feedback. That is a lot of interesting information. I will think it over. Thanks a lot! Greetz M. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted February 24, 2011 Share Posted February 24, 2011 (edited) Use address $02FC. INPUT LDA #$FF STA $02FC ; Reset register LOOP LDA $02FC ; CH holds last key press CMP #$06 ; left arrow BEQ LOOP CMP #$07 ; right arrow BEQ LOOP etc... CMP #$FF ; No key pressed BEQ LOOP INPUT_ROUTINE_GOES_HERE .. .. JMP INPUT If you have a lot of keys you want to exclude it's better to create a table of internal key (characters) values and walk through that. Also, you need to input one character at a time in your routine, not whole words at once. edit: readability... Edited February 24, 2011 by Fox-1 / mnx Quote Link to comment Share on other sites More sharing options...
