Frankie Posted February 24, 2011 Share Posted February 24, 2011 I picked up another 800xl today. It has some mods done to it. One I hadn't heard was replacing the power supply. It came with a modern, light weight, I can't beliieve it replaces that 5 pound thing, plug-in power supply. It was then I realized the Atari only need 5 volts. My question was how many amps does it draw? The new power supply provides only 1 amp max. The old one I have supplied up to 1.5 amps. I didn't know if this would be a problem. Frank Quote Link to comment Share on other sites More sharing options...
sloopy Posted February 24, 2011 Share Posted February 24, 2011 usually .5-.7 amps, depending on config... some XEGS's came with a 1A supply... and no it isnt a problem, unless the machine is sucking down the juice... sloopy. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 24, 2011 Share Posted February 24, 2011 Put enough add-ons and you can exceed 1 Amp... PBI devices, SIO-attached devices that leech power, cartridges, even some stuff that plugs into joystick ports. Internal addons, RAM included. You're often talking in the 5-50 mA range for an addon, but it all builds up. On the other hand, some of the older common PS models have a real bad reputation for failing and allowing excessive voltage through which can kill a machine. So it's probably better to have a reliable PS that you might outgrow rather than one that can do the job but might fail and take out your hardware. Quote Link to comment Share on other sites More sharing options...
