qberticus Posted December 15, 2002 Share Posted December 15, 2002 Does anyone have a link to instructions to make the VCS adapter compatible with the 4-port 5200's? TIA Quote Link to comment Share on other sites More sharing options...
NoahsMyBro Posted December 15, 2002 Share Posted December 15, 2002 I'm almost positive Best Electronics sells the Atari-distributed retrofit kit that the Authorized Factory Service Centers ® themselves used to perfrom the modification, for $5.00. The only drawback is that, at least the last time I ordered, there was a minimum credit card order of about $15, I think (but it might have been $12, might have been $20). The kit includes detailed instructions, as well as a few specific resistors and wires. Just to be clear, it is the 5200 that is modified, NOT the VCS adapter. Best Electronics Quote Link to comment Share on other sites More sharing options...
qberticus Posted December 15, 2002 Author Share Posted December 15, 2002 I'm almost positive Best Electronics sells the Atari-distributed retrofit kit that the Authorized Factory Service Centers ® themselves used to perfrom the modification, for $5.00. The only drawback is that, at least the last time I ordered, there was a minimum credit card order of about $15, I think (but it might have been $12, might have been $20). I checked but didnt see it, which is why I posted here. I sent them an email asking if they still had it, since I don't have a full BE catalog. If anyone has the instructions to do it, can you PM them to me? Chris Quote Link to comment Share on other sites More sharing options...
holygrailvideogames.com Posted December 15, 2002 Share Posted December 15, 2002 I just received the Best Electronics catalog and they still sell the mod. They sell a lot of stuff that is not listed on their website. Quote Link to comment Share on other sites More sharing options...
+Allan Posted December 15, 2002 Share Posted December 15, 2002 I remember seeing instructions for the 5200 mod on Curt Vendal's site, www.atari-history.com. Check the 5200 section. Allan Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted December 15, 2002 Share Posted December 15, 2002 Or to be more precise ... http://209.122.187.156:8080/cx55.html Quote Link to comment Share on other sites More sharing options...
Callipygous Posted December 16, 2002 Share Posted December 16, 2002 Has anyone tried to use the VCS adapter with an 8-bit computer? Given the similarity between the 5200 and the 400, some sort of hookup via the cartridge port seems reasonable. Quote Link to comment Share on other sites More sharing options...
doyman Posted August 13, 2010 Share Posted August 13, 2010 Please forgive or at least overlook the necro-post, but I'm trying to find pictures of this mod installed on a 5200. I have the instructions and the kit but the instructions refer to photos that are not included. Can anyone help a brother out? thanks in advance D Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted September 26, 2010 Share Posted September 26, 2010 I think the 4 port 5200s that have a * in the model number work. Quote Link to comment Share on other sites More sharing options...
Seethransom Posted September 26, 2013 Share Posted September 26, 2013 How do you know if a system has been sent to the factory? Are there any stickers, or marking on the outside of the console suggesting it went to Atari to be fitted? Quote Link to comment Share on other sites More sharing options...
leech Posted July 10, 2019 Share Posted July 10, 2019 Necro'ing this post again. Best Electronics does list the part. Atari 5200 4 port Motherboard PCB part number CA018087 (see 5200 4 port left front top side corner for the Atari 5200 PCB part number) retro fit kit for the above CX55 2600 adapter. Kit requires soldering, cutting 5200 Cartridge connector pins and soldering on a wire harness with components attached to the 5200 4 port motherboard. Kit Includes components, wire hardness with components, Atari Engineering installation instructions. CB101184 $5.00 Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted July 10, 2019 Share Posted July 10, 2019 No problem about necrobumps; as I see it, it's better to bump an old topic than to start a new, redundant one. Just out of curiosity, is it possible for an A/V-modded 5200 to use the CX55 adapter, even if it means making further modifications to the A/V mod? (I'm thinking in particular of a four-port 5200 which supported the adapter prior to the A/V mod.) Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted July 11, 2019 Share Posted July 11, 2019 Should be easy IF the 5200 has a composite only output! The adapter is basically a 2600 with no RF output! Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted July 11, 2019 Share Posted July 11, 2019 Interesting; for some reason, it didn't work for me when I tried it. I figured that some extra modifications might be needed to tie in the A/V signals from the cartridge port. Maybe it was a problem with the adapter, or the games I tested. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted July 12, 2019 Share Posted July 12, 2019 The main issue with most AV mods on the 5200 was the fact that they were intercepting the video out from the GTIA. In thinking about this, the UAV doesn't prevent the video from still working on RF so I wonder if anyone has actually tested a VCS adapter on a 2-port or modified 4-port with a UAV installed? I actually don't own a VCS adapter as I never needed one with the 2600s and 7800s I have on hand already. Quote Link to comment Share on other sites More sharing options...
leech Posted July 17, 2019 Share Posted July 17, 2019 On 7/11/2019 at 11:43 PM, -^Cro§Bow^- said: The main issue with most AV mods on the 5200 was the fact that they were intercepting the video out from the GTIA. In thinking about this, the UAV doesn't prevent the video from still working on RF so I wonder if anyone has actually tested a VCS adapter on a 2-port or modified 4-port with a UAV installed? I actually don't own a VCS adapter as I never needed one with the 2600s and 7800s I have on hand already. I currently have the Sophia mod, and it also doesn't kill the RF output. Was thinking of ordering the mod from Best, but then again it sounds like the 2600 games will only go out the RF, and it's a bit on the fuzzy side! Quote Link to comment Share on other sites More sharing options...
