candle Posted March 14, 2011 Author Share Posted March 14, 2011 there is an atari ultility for flashing all of flash chip content onto it no extra hardware required as for AtariMax stuff - You will have to ask at AtariMax - i've never used this products, so I would not know my guess is it would, but this is only a guess also answering to previous post there is no limitation on what os You could use - just as long as there will be only 4 of them in total - so You need to choose these, which have sense for You Faith of DiamondOS is not determined for now - and considering what Jonathan is doing - I highly doubt I'll put some effort into it (if favor of Jonathan's work) Sebastian Quote Link to comment Share on other sites More sharing options...
thgill Posted March 14, 2011 Share Posted March 14, 2011 When are you going to accept payments for the preorders? Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted March 15, 2011 Share Posted March 15, 2011 Am I too late? I want one; XE. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted March 16, 2011 Share Posted March 16, 2011 Hello Candle, I would like to buy one board as well. With a bit of luck, you can have so many made that they will be the high quality ones, for the low quality price... :-) BR/ Guus Quote Link to comment Share on other sites More sharing options...
Orion Pax Posted March 16, 2011 Share Posted March 16, 2011 Sounds like you replace the OS chip am I right? So this would not work with atarimax's internal myide? At any rate I want 1 as I have more than 1 atari! Since your making a vbxe2 for me as well just hold onto it until you get my 1mb board done and send both at same time! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 16, 2011 Share Posted March 16, 2011 Sounds like you replace the OS chip am I right? So this would not work with atarimax's internal myide? At any rate I want 1 as I have more than 1 atari! Since your making a vbxe2 for me as well just hold onto it until you get my 1mb board done and send both at same time! No, this won't work with an internal MyIDE. There was an older version of MyIDE which fits in the CPU slot: I imagine that would work. The only other option is to make your own (which is what I'm doing). A PBI compliant IDE interface on this board would surely make it the be all and end all of upgrades (as if it wasn't already). However, SpeedDrive should (eventually) take care of our HDD needs... Quote Link to comment Share on other sites More sharing options...
Pac-Man Posted March 16, 2011 Share Posted March 16, 2011 I´ll take one board please - quality. Quote Link to comment Share on other sites More sharing options...
STeSearcher Posted March 17, 2011 Share Posted March 17, 2011 Put me down for 2 quality boards please. I now have to go find the thread with the description of this! Quote Link to comment Share on other sites More sharing options...
Frankie Posted March 28, 2011 Share Posted March 28, 2011 Did I miss out? I want one too! Quote Link to comment Share on other sites More sharing options...
candle Posted March 28, 2011 Author Share Posted March 28, 2011 considering the fact not much of orders were placed after my annoucment, there is no sense to split them into two runs, so the answer is no You didn't Quote Link to comment Share on other sites More sharing options...
BillC Posted March 28, 2011 Share Posted March 28, 2011 considering the fact not much of orders were placed after my annoucment, there is no sense to split them into two runs, so the answer is no You didn't The orders may have tapered off because of your announcement, some people might be waiting till the announcement that you are taking orders for the second run. In spite of it there have still been requests for another 22 boards, plus another 3 tentative, so you would still have been close to minimum order numbers for a second run. We are still before the original cutoff date you set in the first post. Quote Link to comment Share on other sites More sharing options...
candle Posted March 28, 2011 Author Share Posted March 28, 2011 that might be Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 29, 2011 Share Posted March 29, 2011 Info needed for another project: What hardware ROM banking registers does U1MB use (for built-in SDX)? Are they the same as other IntSDX boards? What hardware registers are used by the RTC? Are they the same as the ARC clock? Any other hardware registers used (for alternate RAM banking, etc)? Quote Link to comment Share on other sites More sharing options...
candle Posted March 29, 2011 Author Share Posted March 29, 2011 ultimate emulates bits of pia, gtia, and has registers of its own i can make you full register map if you want me to Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted March 29, 2011 Share Posted March 29, 2011 Hmm, missed this earlier. I'm up for one, quality of course. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 29, 2011 Share Posted March 29, 2011 that might be And what about your hardware to software shift announcement Quote Link to comment Share on other sites More sharing options...
IndusGT Posted March 29, 2011 Share Posted March 29, 2011 (edited) when can we expect this? Has this been delayed because of the other project? Thanks Edited March 29, 2011 by IndusGT Quote Link to comment Share on other sites More sharing options...
Beetle Posted March 29, 2011 Share Posted March 29, 2011 Hi Candle, i'll take one for my 1200XL. Greetings, Beetle Quote Link to comment Share on other sites More sharing options...
candle Posted March 29, 2011 Author Share Posted March 29, 2011 preorder ends with end of this month - so nothing is delayed, project is going on as scheluded Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 29, 2011 Share Posted March 29, 2011 ultimate emulates bits of pia, gtia, and has registers of its own i can make you full register map if you want me to Yes please: this would be useful to me, and perhaps also to others. I'm trying to draw up a list of popular upgrades/peripherals and the hardware registers they use, in order to identify some "free" space. The sooner the better. Quote Link to comment Share on other sites More sharing options...
Raul Vasbutin Posted March 29, 2011 Share Posted March 29, 2011 If possible, with news that a second run is not needed, please increase my order from 1 to 2. Many thanks! Byron Quote Link to comment Share on other sites More sharing options...
skitt Posted March 29, 2011 Share Posted March 29, 2011 Count me in too (I just joined the forum so I could sign up for this pre-order!), if necessary in the second run, for one quality unit for use in an 800XLF. Quote Link to comment Share on other sites More sharing options...
Mathy Posted March 30, 2011 Share Posted March 30, 2011 Hello Candle Could you give me a quick reminder of what makes this upgrade different from other memory upgrades (including my own)? sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 30, 2011 Share Posted March 30, 2011 Hello Candle Could you give me a quick reminder of what makes this upgrade different from other memory upgrades (including my own)? sincerely Mathy to sum it up - its a 1mb memory module containing 4 OS slots, basic, missle command (or any other 8k game) for xegs, and sparta dos x with RTC module all of above is flashable, and if some features are not needed - can be disabled by setup program I also believe it only needs minimal wiring internally... But I'll let Candle answer that one Quote Link to comment Share on other sites More sharing options...
candle Posted March 30, 2011 Author Share Posted March 30, 2011 what the Simon says Quote Link to comment Share on other sites More sharing options...
