Thomas Jentzsch Posted March 7, 2011 Share Posted March 7, 2011 Any idea how to pass variables instead of constant numbers to a macro? E.g. instead of "MACRO 1" I would like to do "MACRO variable". But when I do this outside an expression, inside the macro {1} is converted into the string "variable" and not the content of the variable. MAC TEST Label{1} .byte {1} ENDM variable SET 10 TEST variable This works for the .byte instruction, but not for the label. I get "Labelvariable" instead of "Label10". Any ideas? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted March 8, 2011 Share Posted March 8, 2011 Any idea how to pass variables instead of constant numbers to a macro? E.g. instead of "MACRO 1" I would like to do "MACRO variable". But when I do this outside an expression, inside the macro {1} is converted into the string "variable" and not the content of the variable. MAC TEST Label{1} .byte {1} ENDM variable SET 10 TEST variable This works for the .byte instruction, but not for the label. I get "Labelvariable" instead of "Label10". Any ideas? I have an idea, but you might not like it-- although it's the only thing I could get to work. Define a macro called LABEL, as follows: MAC LABEL if <{1} == 0 Label0 endif if <{1} == 1 Label1 endif if <{1} == 2 Label2 endif ; etc. if <{1} == 10 Label10 endif ; etc., up to if <{1} == 255 Label255 endif ENDM This assumes that the variable you're going to pass to your macro will be set to a value between 0 and 255. Then you can call the LABEL macro from inside your other macro, as follows: MAC TEST LABEL {1} BYTE {1} ENDM Then this works: variable SET 10 TEST variable The output is as follows: Label10 BYTE variable ; which gives you a byte of $0A The only reason I suggest defining a macro called LABEL is in case you want to call it from inside multiple macros. Michael Quote Link to comment Share on other sites More sharing options...
