bar897 Posted March 7, 2011 Share Posted March 7, 2011 I posted a few years back about my Atari 400 keyboard and never repaired it. My shift, ctrl, and the 4 yellow keys at the right do not work. Everything else does. I've tried cleaning the keyboard connection and it didn't work. I'm guessing I need a new keyboard. Does anyone have a working keyboard I can get? I tried Best but they didn't seem to have any. My other question is, how much are the game cartridges typically? I have the BASIC cartridge, but no games. Quote Link to comment Share on other sites More sharing options...
mimo Posted March 7, 2011 Share Posted March 7, 2011 best do have them, but they are not listed, you have to email Brad Myatari.com also have them, at a higher price Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 8, 2011 Share Posted March 8, 2011 Actually I emailed both of them a month ago, Myatari said he can't find any in his "warehouse" and Brad said he was out. Quote Link to comment Share on other sites More sharing options...
+David_P Posted March 8, 2011 Share Posted March 8, 2011 I may have a 400 keeyboard in a box in the basement - if you're having no joy finding one from another source, PM me. Probably be a week or two before I can find it, though. Quote Link to comment Share on other sites More sharing options...
mimo Posted March 8, 2011 Share Posted March 8, 2011 oh no, looks like I bought the last one from Brad then Was going to order another to replace the full stroke keyboard on my other 400, guess that is not going to happen now Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted March 8, 2011 Share Posted March 8, 2011 Did you clean all of the Male conductors (on both sides) on the end of the Keyboard's Flexi-Cable? Use a new #2 pencil's pink eraser, to erase the tarnish, vertically, inline with each conductor, one by one, about 4-5 times per conductor. TV Tuner Cleaner or Rubbing alcohol is good to use to clean the conductors in the Female connector. If the 400 Keyboard is totally dead, it can still be Framed Art, since it has such cool industrial design, and is so colorful... Wipe it down with Armor-All Original, and frame it with a glass-faced frame, it looks amazing after it has been Armor-All-ed. Great Hacker Art for Home or Office. Quote Link to comment Share on other sites More sharing options...
bar897 Posted March 8, 2011 Author Share Posted March 8, 2011 Thanks everybody, Did you clean all of the Male conductors (on both sides) on the end of the Keyboard's Flexi-Cable? Use a new #2 pencil's pink eraser, to erase the tarnish, vertically, inline with each conductor, one by one, about 4-5 times per conductor. TV Tuner Cleaner or Rubbing alcohol is good to use to clean the conductors in the Female connector. I did clean the male connectors but not with an eraser. I'll try that. I did not clean the female connector though. I found the System Reset key actually is working, unlike what I said, so I believe all of those 4 keys at the right should be okay. So it's really just the shift and ctrl keys that don't. I remember someone on here named Corey said he had some of the 400 keyboards, but I don't know if he still does. Quote Link to comment Share on other sites More sharing options...
bar897 Posted March 8, 2011 Author Share Posted March 8, 2011 Ok, I just tried cleaning the contacts with an eraser and scrubbed the female connector with a toothbrush and alcohol, but it still seems to be the same. At one point when I pressed the shift key and 1 key I heard a strange sound from the speaker and the screen flickered, but then it stopped. It looks like I'm going to have to replace it. Also, is it okay if the pins still have dark spots or is that corrosion too? To me it just looks like wear spots. Thanks. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 8, 2011 Share Posted March 8, 2011 oh no, looks like I bought the last one from Brad then Was going to order another to replace the full stroke keyboard on my other 400, guess that is not going to happen now Well you never know, he's been known to "find" things in his "warehouse" Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted March 8, 2011 Share Posted March 8, 2011 Have you re-seated all of the ICs (chips)? It could be that your POKEY just needs to be re-seated. While grounded properly, press firmly & slide the sides of both thumbs outward from the center of the POKEY, to it's edges, a few times until you stop hearing "creaking" noises, then test it out. Quote Link to comment Share on other sites More sharing options...
bar897 Posted March 8, 2011 Author Share Posted March 8, 2011 Have you re-seated all of the ICs (chips)? It could be that your POKEY just needs to be re-seated. While grounded properly, press firmly & slide the sides of both thumbs outward from the center of the POKEY, to it's edges, a few times until you stop hearing "creaking" noises, then test it out. Ok, I pushing all of the chips down until they stopped creaking, and tried it again but it still won't work. I also removed the ram and cpu boards and did those chips. However, I did notice that with the case off of the computer, if I move the keyboard a certain way, the System Reset key works. If it's positioned how it would be in the case, then the key doesn't work. I think there must be a break in the cable somewhere. Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted March 9, 2011 Share Posted March 9, 2011 It could be that your POKEY just needs to be re-seated. Those "4 keys at the right" are handled by the GTIA (or CTIA), not PoKey. Quote Link to comment Share on other sites More sharing options...
+David_P Posted March 9, 2011 Share Posted March 9, 2011 Follow-up: I have found my 400 keyboard in one of my bins-o-Atari-stuff. If you need it, send me a PM. Quote Link to comment Share on other sites More sharing options...
