Marius Posted March 26, 2011 Share Posted March 26, 2011 I suppose a 0 Ohm resistor is replacable by just a wire? I want to 'downgrade' an Atari 130XE to 65XE. I need to install those 0 Ohm resistors on the place of that special memory management chip. After that I'll install Hiass 512KB Sram upgrade in it. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted March 26, 2011 Share Posted March 26, 2011 Yep! A wire is just as good. Quote Link to comment Share on other sites More sharing options...
fibrewire Posted March 26, 2011 Share Posted March 26, 2011 Zero ohm resistor is used instead of jumper wires because it would require a separate welding machine to hold jumper wires at the manufacturing plant. EDIT: Link to Wikipedia Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted March 26, 2011 Share Posted March 26, 2011 I have a bucket full of 1 ohm resistors that are essentially the same as wire. I think they look better than wire and even as much as 47 ohms would do the job. Some of the signal paths have 33 ohm resistors in them to reduce noise on the circuit, so throwing in some 47s won't be a problem. (there are some jumpers that provide power to an IC pin - know what you are doing... that would take a 1 ohm) Bob I suppose a 0 Ohm resistor is replacable by just a wire? I want to 'downgrade' an Atari 130XE to 65XE. I need to install those 0 Ohm resistors on the place of that special memory management chip. After that I'll install Hiass 512KB Sram upgrade in it. Quote Link to comment Share on other sites More sharing options...
