Marius Posted April 6, 2011 Share Posted April 6, 2011 Hi One of my 800XL's is having strange issues. I was using it with a custom rom, that had not the "checksum" routines, so the Atari worked great... untill I tried to enable basic, which resulted in a crash. Now I installed the default OS and the Atari selftest starts, and I have one bar RED. I'm pretty sure that: The BASIC ROM = OK The OS ROM = OK Since I had problems with going to basic with the Custom OS Rom, I was wondering: Which parts are involved with the Basic Rom? I had a blown LS08 in this computer (static electricity?) so I replaced it, and the computer started again. But it was not enough fix... Anyone has an Idea RAM = OK Where to start? Greetz M. Quote Link to comment Share on other sites More sharing options...
Marius Posted April 6, 2011 Author Share Posted April 6, 2011 Hmmm I replaced the 20 pins PAL C061618 ... is this the MMU? That was the trick. I was wondering: is this part replacable by a GAL? Has someone JEDEC file for that? And which GAL to use? Thanks M. Quote Link to comment Share on other sites More sharing options...
+Guitarman Posted April 7, 2011 Share Posted April 7, 2011 From another source. The Atari MMU is a custom MMU chip for the Atari 8-bit computers. It enables access to the hardware registers on ANTIC, GTIA, POKEY and 6520 PIA. The later XL/XE MMU (C061618) also selects OS ROM, Atari BASIC ROM, self-test ROM and LEDs in the 1200XL. The user cannot directly manipulate the Atari MMU, but selects the various ROMS and memory via the memory-mapped hardware register known as PORTB (5401710 or D30116). Atari changed PORTB from an input port on the 400/800 machines to an output port on the XL/XE machines, leaving two joystick ports instead of four on the XL/XE machines. By setting and clearing specific bits in PORTB, the user can access either the ROMs or memory location. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 7, 2011 Share Posted April 7, 2011 Hmmm I replaced the 20 pins PAL C061618 ... is this the MMU? That was the trick. I was wondering: is this part replacable by a GAL? Has someone JEDEC file for that? And which GAL to use? Here you go: mmupal.zip You need a 16v8. Useless to me, since although I have GALs, the crappy eBay programmer won't write them. 1 Quote Link to comment Share on other sites More sharing options...
Marius Posted April 7, 2011 Author Share Posted April 7, 2011 I ihave the g540 I guess that one does the trick... Quote Link to comment Share on other sites More sharing options...
santosp Posted July 27, 2012 Share Posted July 27, 2012 (edited) After one year from original post, the same issues here on my 800XL. What a pity not to see this thread earlier. One day with much effort measurements etc. I believe cause it should be done a "tech attachment". A big thanks to flashjazzcat for the file. Edited July 27, 2012 by santosp Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted July 27, 2012 Share Posted July 27, 2012 Hi, Marius, do you still need a replacement? I can you send one or two, I have enough 16V8 and to the netherlands it´s cheap shipping. Jürgen Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted July 27, 2012 Share Posted July 27, 2012 You can program a PAL from the file, can't you? Usually, the programmer sets up the device as a 16V8 in 16L8 mode. The file is actually a 16L8 file and should work fine on a 16L8. (use a quarter-power 16L8) Bob Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted July 27, 2012 Share Posted July 27, 2012 I also have an 800xl that is going to selftest. And I was wondering if the MMU I took out of the 130XE to install a Ultimate1 would work in the 800xl. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted July 27, 2012 Share Posted July 27, 2012 I also have an 800xl that is going to selftest. And I was wondering if the MMU I took out of the 130XE to install a Ultimate1 would work in the 800xl. Yup, it would. Quote Link to comment Share on other sites More sharing options...
