A_Locomotive Posted May 16, 2011 Share Posted May 16, 2011 (edited) I do this all the time. Bought this today, not game related but it was so odd it caught my attention. Was at a record store and found this in the used section. Its a 3" mini cd by Sigur Ros. That is all I knew when I found it. But it had such cool packaging coming in a little mini digipak with a clear clam shell case to hold it. Didn't know if it was a single, EP or something else entirely. Since it was only 2 bucks I bought it just to find out. Turns out its a single for the song Untitled (Vaka) off of the album (). Also on it are 3 remixes of the song, all of which are fantastic! Edited May 16, 2011 by A_Locomotive Quote Link to comment Share on other sites More sharing options...
ATARI7800fan Posted May 16, 2011 Share Posted May 16, 2011 I do occasionally if a game catches my eye, also with consoles. Quote Link to comment Share on other sites More sharing options...
BigO Posted April 21, 2012 Author Share Posted April 21, 2012 Haha, very nice! So you could indeed try using it as a pointing device on your PC after you get or build an adapter. I ran across this controller again today while cleaning a closet. I looked at the spec. documents in detail. Seeing the data format for "Coordinate Devices" made me a bit suspicious of something. I cross referenced it with the specs for a different serial pointing device and sure enough, it looks like the track ball/mouse CDi controllers use the same protocol as an old PC serial mouse. I may build an adapter too hook this up to a 9 pin serial port and dig out an old computer that will directly use the RS-232 mouse. Maybe I can ultimately use this thing as a mouse on a more current computer by using a USB/RS-232 adapter... Quote Link to comment Share on other sites More sharing options...
