Digitized Sound on Aquarius
I can tell you one thing that won't work. I tried to use a noise reduction filter by taking the noise from the output of the 1,0,1,0,1,0,1,0 and using a noise reduction filter on the input sound before I processed it. What I got was a sample that sounded underwater, when I ran that through the converter, I got a sample that sounded underwater with noise!
Ha!
Interesting asymmetry there on your triangle wave. When the signal's decreasing, there's that bit of thrashing right after the triangle goes below 0. I wonder if there's a problem in the SDM computation? I'm going to try a triangle right now and see for myself in my own sdm code...
Ok, so I put my own SDM to the test and constructed this striking picture:
So at least my code's doing OK. (The blue/black in the background indicate whether the SDM output is 0 or 1, and the white is the triangle wave I fed it.) Here's the C program:
#include < stdio.h >
#include < stdlib.h >
#define NSAMP (128)
#define OSAMP (
short           i_data[NSAMP];
unsigned char   o_data[NSAMP*OSAMP];
int main()
   int i, y, x;
   FILE *f;
   for (i = 0; i < NSAMP/2; i++)
       i_data[i          ] = -32767 + 65534*i / (NSAMP/2-1);
       i_data[i + NSAMP/2] = 65536 - i_data[i];
   sdm(i_data, o_data, NSAMP, OSAMP, 32767);
   f = fopen("foo.ppm", "wb");
   fprintf(f, "P6\n%d 512 255\n", NSAMP * OSAMP);
   for (y = 0; y < 512; y++)
       int hi = 32767 -   y   * (65536/512);
       int lo = 32767 - (y+1) * (65536/512);
       for (x = 0; x < NSAMP * OSAMP; x++)
           i = x / OSAMP;
           if (i_data[i] <= hi && i_data[i] >= lo)
               fputs("\377\377\377", f);
           } else if (o_data[x])
               fputs("\070\070\377", f);
           } else
               fputs("\001\001\001", f);
   fclose(f);
   return 0;
It wrote the image you see above as a PPM file -- nothing terribly crazy. You might want to check the output of your SDM converter directly just to make sure it looks nice and clean like this on both halves of the triangle.
Edit: The AA comment software really doesn't like things in angle brackets even if they're in a code block. Annoying.
Edited by intvnut
This looks bogus:
           audio(j)=audio(j)+4000*rnd-2000
Since you declare 'audio' as short, what's to stop the random noise you're injecting from overflowing the 16-bit range?
I'd try taking the dithering out altogether. SDMs naturally dither. Have you tried it without your stochastic dither now that we've cleaned up the bit-banging loop?
This looks bogus:
Good Catch, the dither has been turned off for a while so that we can hear what the converter itself is doing. I can always add dither back to mask the "swish/swish" noise left over, but you are right that I would have to clip check if I were doing that.
