Marius Posted April 24, 2011 Share Posted April 24, 2011 There is something strange going on with the BIT instruction. I was wondering: is this instruction only giving a usable result when you check the status of one bit at the time? Please take a look at this code: On memory location $0600 I saved value #$14 (%00010100) .OR $5000 START LDA #$04 BIT $0600 BNE TRUE FALSE LDA #$00 STA COLPF2 RTS TRUE LDA #$C0 STA COLPF2 RTS OK this works great. It tests for bit 2 (#$04) and indeed this bit is SET so the screen turns green (the TRUE routine) But now the same code, except for the START line... On memory location $0600 I saved value #$14 (%00010100) .OR $5000 START LDA #$24 BIT $0600 BNE TRUE FALSE LDA #$00 STA COLPF2 RTS TRUE LDA #$C0 STA COLPF2 RTS And AGAIN the screen turns Green (the TRUE routine!) ... this is strange in my opinion since bit 5 isn't true on $0600. I thought: this should result in a black screen. This routine gives a black screen: On memory location $0600 I saved value #$14 (%00010100) .OR $5000 START LDA #$20 BIT $0600 BNE TRUE FALSE LDA #$00 STA COLPF2 RTS TRUE LDA #$C0 STA COLPF2 RTS So I only can conlude: the BIT routine is only usable for BIT checking, one bit at a time. Is this a right conclusion? thanks Marius Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted April 24, 2011 Share Posted April 24, 2011 On memory location $0600 I saved value #$14 (%00010100) .OR $5000 START LDA #$04 BIT $0600 BIT performs a logical AND between the accumulator and the memory location (as well as updating the N and V flags with bits 7 and 6 respectively from the memory location) so %00000100 AND %00010100 = %00000100 Which is a result not equal to zero. On memory location $0600 I saved value #$14 (%00010100) .OR $5000 START LDA #$24 BIT $0600 %00100100 AND %00010100 = %00000100 Which is a result not equal to zero. If you want to check multiple bits you'll have to AND #MASK and CMP #MASK unless you can get the bits of interest into bits 6 and 7. 1 Quote Link to comment Share on other sites More sharing options...
