Jr. Pac Posted May 2, 2011 Share Posted May 2, 2011 Will an Atari 400/800 power supply work with the Atari 800XL or Atari XE? Does the XE have 48k of RAM? I recently went to the flea market and found controllers, TV hookups, and power supplies, all at the same booth, but no system. =( I also want to play Jr. Pac-Man. Quote Link to comment Share on other sites More sharing options...
4hubbs Posted May 2, 2011 Share Posted May 2, 2011 The power supplies are different, the connectors are different. I believe the XE computers have 64K. Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 2, 2011 Share Posted May 2, 2011 Atari 400/800 uses a barrel plug connector Atari XL/XE uses a 5 pin DIN connector In depth information and part numbers are in the FAQ here http://www.atari8.com/node/215 Stock XE memory is 65XE 64k 130XE 128k Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted May 2, 2011 Share Posted May 2, 2011 What he said. 400/800/1200XL power supply is like the disk drives 810/1050/XF551 and the 850 interface module. 9V AC and round barrel connector. They may look like this.... ....with one cord coming out of each end of the brick. Or they could look like this.... .....with both cords out of the same end. In either case, the connector will look like this..... The 600XL/800XL/65XE/130XE/XE Game System all use 5V DC and the power supply will look like one of these..... .....and the connector will look like this: Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 2, 2011 Share Posted May 2, 2011 you know, the FAQ should be updated with graphics and hosted here! I volunteer Wood to do it! Quote Link to comment Share on other sites More sharing options...
spookt Posted May 2, 2011 Share Posted May 2, 2011 you know, the FAQ should be updated with graphics and hosted here! I volunteer Wood to do it! Seconded Quote Link to comment Share on other sites More sharing options...
+poobah Posted May 3, 2011 Share Posted May 3, 2011 XL/XE's have 7 pins in the power supply connector. Quote Link to comment Share on other sites More sharing options...
zylon Posted May 3, 2011 Share Posted May 3, 2011 Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted May 3, 2011 Share Posted May 3, 2011 XL/XE's have 7 pins in the power supply connector. I was wondering if anyone would notice that... I realized after my edit window had closed. Quote Link to comment Share on other sites More sharing options...
sloopy Posted May 3, 2011 Share Posted May 3, 2011 i saw it immediately... sloopy. Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted May 4, 2011 Share Posted May 4, 2011 EXACTLY! I tried. Sorry, guys. :dunce: :dunce: Quote Link to comment Share on other sites More sharing options...
fibrewire Posted May 4, 2011 Share Posted May 4, 2011 EXACTLY! I tried. Sorry, guys. :dunce: :dunce: Get a subscription, and you can edit up to two weeks later - i do it all the time Quote Link to comment Share on other sites More sharing options...
Jr. Pac Posted May 7, 2011 Author Share Posted May 7, 2011 Right on it, it says "For use with ATARI 400/800 Personal Computer System. Quote Link to comment Share on other sites More sharing options...
Jr. Pac Posted May 15, 2011 Author Share Posted May 15, 2011 bump Quote Link to comment Share on other sites More sharing options...
mimo Posted May 15, 2011 Share Posted May 15, 2011 bump Why? Quote Link to comment Share on other sites More sharing options...
