RAM disk initialization
I have a 256k HRD I am trying to get initialized with my TI. It has previously been in a Geneve system and worked fine. I'm using ROS 8.14F and when I try to load the ROSTICC file I keep getting an error message. The CFG program recognizes the HRD and tells me theres an 8K*8 HORIZON at 1400 CRU with 250K and that RAMBO is OK. Other cards in the PEB are the standard ones (TI 32k, TI RS232, CorComp 9900 disk controller). Any ideas? Thanks.
Edited by Mad Hatter
Tried the battery thing, didn't work. Must've been a corrupted ROSTICC file. Got ahold of one from a different source and it worked fine.
I have a 256k HRD I am trying to get initialized with my TI. It has previously been in a Geneve system and worked fine. I'm using ROS 8.14F and when I try to load the ROSTICC file I keep getting an error message. The CFG program recognizes the HRD and tells me theres an 8K*K HORIZON at 1400 CRU with 250K and that RAMBO is OK. Other cards in the PEB are the standard ones (TI 32k, TI RS232, CorComp 9900 disk controller). Any ideas? Thanks.
With the card removed from the Pbox, remove the batteries and let it sit for a few minutes so all the ram is cleared. Put the batteries back in and reinstall the card in the Pbox. The Horizon doesn't like being switched back and forth from Geneve & TI when there are remnants of the other DSR present.
Tony
