guus.assmann Posted May 19, 2011 Share Posted May 19, 2011 Is there a version of GFA Basic that works on a Falcon? And what mode or configuration should I use then. I do have some versions, among which a 3.6 that works on a TT 030. But this doesn't work on the Falcon. Where can I get a working version for the Falcon? Quote Link to comment Share on other sites More sharing options...
Christos Posted May 19, 2011 Share Posted May 19, 2011 3.6TT does work on the falcon. You just need to start it from either a TT or an ST compatible resolution. GBE will work as well. Quote Link to comment Share on other sites More sharing options...
simonsunnyboy Posted May 22, 2011 Share Posted May 22, 2011 I second Christos but I also want to detail his statement. 640x480 16 colors VGA mode works best with 3.6TT but I would strongly recommend using GBE, esp. if you are already running a multitasking OS like Mint or MagiC on your Falcon. Quote Link to comment Share on other sites More sharing options...
guus.assmann Posted May 22, 2011 Author Share Posted May 22, 2011 Yesterday I've tested it, and if I choose compatibility-modus it works fine. But the it's only in 2 colors of course. I've been using no other things than the most rudimentary setup. With the exception of a CF-card instead of the IDE-HD. What's GBE ? I'm not familiar with this. Quote Link to comment Share on other sites More sharing options...
lp060 Posted May 22, 2011 Share Posted May 22, 2011 Yesterday I've tested it, and if I choose compatibility-modus it works fine. But the it's only in 2 colors of course. I've been using no other things than the most rudimentary setup. With the exception of a CF-card instead of the IDE-HD. What's GBE ? I'm not familiar with this. GBE is a short name for a revised GFA-Basic Editor I created. Unlike the old editor that doesn't play well with multi-tasking, mine does. In fact mine does not play well with single-tasking. Its 100% token compatible with the v3.6 and many bugs squashed in the compiler, linker, and library. Can be found here: http://userpages.bright.net/~gfabasic/html/gfabasic.htm If you are using plain old SingleTOS, use the old gfa editor. If you are using some tasking OS, you have two options: Old GFA editor with some patch, like Bastard (yes, funny name for a patch) or GBE. Quote Link to comment Share on other sites More sharing options...
