ACML Posted May 21, 2011 Share Posted May 21, 2011 I'm about to install Bob's ClearPic2002 modification on my 1200XL. Bob saved my 1200XL with a working keyboard (Thanks Bob1200XL!!). The question I had concerns the last step in the instructions I found on the Retrobits website. The final wire that connects the Chroma back to pin 2 on the monitor jack, is that supposed to be a shielded wire? What gauge? If it's shielded, what do I ground it to? Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 21, 2011 Share Posted May 21, 2011 When adding the chroma to my 800XL I just used a normal insulated wire, about the same type as used for power leads inside a PC. That's overkill, you'd probably do just as well using a much finer wire. I doubt using shielded wire would make much difference although the 1200XL does have the internal power conversion circuitry that might be a potential source of interference. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 21, 2011 Share Posted May 21, 2011 I'm about to install Bob's ClearPic2002 modification on my 1200XL. Bob saved my 1200XL with a working keyboard (Thanks Bob1200XL!!). The question I had concerns the last step in the instructions I found on the Retrobits website. The final wire that connects the Chroma back to pin 2 on the monitor jack, is that supposed to be a shielded wire? What gauge? If it's shielded, what do I ground it to? Shouldn't that be pin 5, but any mid size sheilded wire will do? And any larger ground like the RF shield. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted May 21, 2011 Share Posted May 21, 2011 I just use wire-wrap wire, 34 ga. solid. (I think) For short runs on a two-sided board, it is pretty much the same as a trace on the PCB. I don't remember any significant noise on the CHROMA line and if there is, it is from poor ground/power traces, not shielding. Even if the CHROMA line does have noise on it, it is a phase-modulated signal. Any noise is not a factor in the decoder. Bob I'm about to install Bob's ClearPic2002 modification on my 1200XL. Bob saved my 1200XL with a working keyboard (Thanks Bob1200XL!!). The question I had concerns the last step in the instructions I found on the Retrobits website. The final wire that connects the Chroma back to pin 2 on the monitor jack, is that supposed to be a shielded wire? What gauge? If it's shielded, what do I ground it to? Quote Link to comment Share on other sites More sharing options...
