littleman jack Posted June 3, 2011 Share Posted June 3, 2011 The subject of how well 2600 paddles work on the various 8-bit computers came up in the high score club recently, and apparently the paddles don't work as well on the XL and XE models as they do on the two original tanks (400 and 800). Is this the case with any other controllers? Are the 7800 prolines and joypads okay to use on the various 8-bit systems? Are any controllers unusable, or not advisable? I once read that some Sega controllers could actually damage Ataris due to voltages that they sent into the consoles. But I don't know if that's actually possible since I don't understand how the controllers actually work. Does anyone know the answers to any of my ramblings? I generally use the CX40 or a WICO stick (ball, bat, or boss). Thanks in advance for any input. Quote Link to comment Share on other sites More sharing options...
zylon Posted June 3, 2011 Share Posted June 3, 2011 I use a pair of Genny controls on Robotron. Had no problems yet. 1 Quote Link to comment Share on other sites More sharing options...
littleman jack Posted June 3, 2011 Author Share Posted June 3, 2011 I use a pair of Genny controls on Robotron. Had no problems yet. I've used a Genesis controller on Montezuma's Revenge, also with no problems. The Sega controllers that I read about, that were said to be detrimental, were the Master System controllers. But I have absolutely no experience with them. Quote Link to comment Share on other sites More sharing options...
zylon Posted June 3, 2011 Share Posted June 3, 2011 (edited) I use a pair of Genny controls on Robotron. Had no problems yet. I've used a Genesis controller on Montezuma's Revenge, also with no problems. The Sega controllers that I read about, that were said to be detrimental, were the Master System controllers. But I have absolutely no experience with them. Should be even less of a chance of damage using SMS controls. All they are inside is direct circuits with no IC's or anything else. Not much more than a CX40 with an extra output. Genny controls have 3 extra outputs and internal IC that some directionals and fire buttons run through instead of being wired directly. I've also used two SMS sticks on Robotron. Edited June 3, 2011 by zylon 1 Quote Link to comment Share on other sites More sharing options...
littleman jack Posted June 3, 2011 Author Share Posted June 3, 2011 Thanks for the info! I never knew. Are they anywhere near as comfortable, or sturdy, as the Genesis controllers? Quote Link to comment Share on other sites More sharing options...
zylon Posted June 3, 2011 Share Posted June 3, 2011 (edited) As long as you don't get the "made in China" ones, they're durable. I've been using the same ones since '87. Comfortable is a matter of opinion. I might be just used to them so I don't mind, but I do prefer the Genny 3-button controls for a few games. The diagonals are better on Genny stuff. The only SMS controls I found any evidence of causing damage are the Sega Sports Pad(track ball), and the Sega Paddle Control(Japan only). Edited June 3, 2011 by zylon Quote Link to comment Share on other sites More sharing options...
