thomas3120 Posted June 10, 2011 Share Posted June 10, 2011 (edited) Hello, I posted this on the Sega16 forums, I thought I would post it here as well. I copied pretty much what I posted over at Sega16. Just finished a Sega Neptune mod. Everything works great but getting a 'flickering' horizontal line interference in the video. All my cables I used to connect the 32X to the Genesis model 2 are the shielded type (cables from CD-ROM audio with ground wrapped around signal wires). Genesis games work fine..no interference, just when I play a 32X game. I am using an internal power adapter to convert 120V AC to 10V DC (3.1 Amps) Wondering if you guys had any suggestions. ---------------------------------------- Here is a video: http://www.youtube.com/watch?v=Ml4LKEMPdak ---------------------------------------- I moved the power supply out and away from the unit...no change. However, I did run a ferrite cylinder near the 32X's choke/coil and the interference went away... So..possibly it's the choke/coil on the 32X?.. t Edited June 10, 2011 by thomas3120 Quote Link to comment Share on other sites More sharing options...
