chjmartin2 Posted March 14, 2012 Author Share Posted March 14, 2012 I tried to attach some samples and code, but the forums have way too restrictive rules (seriously, I can't attach a .c file?). I uploaded here instead: http://www.acc.umu.s...ppen/files/vcs/ Is the output you have out there from a real VCS or is it just the simulated 5 bit output? I'm curious to know because the output with the shaping that says 5 bps is really incredible? What is the sampling rate you are looking at? Could you write a decoder for this? I wonder if you could put a really dead simple title screen in and play background music using this method. It would make for incredible never before heard of sound on the VCS! Quote Link to comment Share on other sites More sharing options...
Tjoppen Posted March 14, 2012 Share Posted March 14, 2012 chjmartin2: I had a ROM that decodes the 1-bit samples and outputs as 5-bit PCM. Unfortunately I seem to have misplaced both the code and ROM, but the output sounded very close to the .wav output. Quote Link to comment Share on other sites More sharing options...
