Rex Dart Posted July 6, 2011 Share Posted July 6, 2011 Hi, I've had this model 2 Genesis sitting around for several years. It was given to me because the 1st player's control port doesn't appear to work at all. Is this a known issue, hopefully with a known fix? Should I just throw it out? Use it for a case for a modded Radica sega? Quote Link to comment Share on other sites More sharing options...
zylon Posted July 7, 2011 Share Posted July 7, 2011 Board might be cracked from being stepped on/dropped. I've seen that often. Quote Link to comment Share on other sites More sharing options...
STICH666 Posted July 8, 2011 Share Posted July 8, 2011 The solder joints get brittle over time. I've seen it happen alot on DB9 connectors mainly in Coleco Gemini's. Just reflow the solder and it should be fine. 2 Quote Link to comment Share on other sites More sharing options...
nathanallan Posted July 8, 2011 Share Posted July 8, 2011 Agreed with Stitch, it might be that the port got used so much, plugging and unplugging that the contacts have broken loose from the board. And stepping on it will definitely break something. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 8, 2011 Author Share Posted July 8, 2011 Cool, I'll give that a try when I find the damned thing... it's been packed away since my last move. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted July 9, 2011 Share Posted July 9, 2011 Bad solder joints. Reflow 'em. I found a Gen2 once where about half the solder joints on both ports and the power jack were bad. Quote Link to comment Share on other sites More sharing options...
DickNixonArisen Posted July 10, 2011 Share Posted July 10, 2011 Yep. Easy. I wouldn't say common in the gen, i've had more than ten model 2's (they're SO cheap, how can I say no?) and never seen that particular problem. The gemini, for sure. Love that thing but it was made very shoddily; plastic too. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 14, 2011 Author Share Posted July 14, 2011 (edited) Cool, solder reflow fixed it. Thanks for the suggestion. Incidentally, anybody know where to get replacement screws for it? This one has no case screws... Edited July 14, 2011 by Rex Dart Quote Link to comment Share on other sites More sharing options...
captcapcom Posted July 20, 2011 Share Posted July 20, 2011 (edited) -- Reply Deleted -- Edited July 20, 2011 by captcapcom Quote Link to comment Share on other sites More sharing options...
nathanallan Posted July 20, 2011 Share Posted July 20, 2011 Use box tape, it's clear and gives a neat sheen around the edges. Works for me when I have any kind of case that doesn't have screws, and holds for years. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted July 20, 2011 Author Share Posted July 20, 2011 True, but I want to build a 32x into this case and tape doesn't fit into my plans so well. Any chance that the 32x's own screws will fit? Guess I can try later. Quote Link to comment Share on other sites More sharing options...
