esplonky Posted July 17, 2011 Share Posted July 17, 2011 (edited) every time i use one of RT's tutorials i always get this when i put his code into mine, and it's usually because of dim. this is the error: [root@Esplonky pong]# make 2600basic.sh default.bas -O Starting build of default.bas 2600 Basic compilation complete. DASM V2.20.09, Macro Assembler ©1988-2003 bytes of ROM space left 2302 bytes of ROM space left 2302 bytes of ROM space left --- Unresolved Symbol List pfcenter 0000 ???? (R ) ball0x 0000 ???? (R ) ball0y 0000 ???? (R ) kernelmacrodef 0000 ???? (R ) then 0000 ???? (R ) pfhalfwidth 0000 ???? (R ) Fatal assembly error: Source is not resolvable. Build complete. \n > > > Compile of default.bas FAILED! > > >\n [root@Esplonky pong]# here is my source code: pong_Esplonky_july_17_2011_error.bas Edited July 17, 2011 by esplonky Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 17, 2011 Share Posted July 17, 2011 There's no "ball0x" or "ball0y" defined in bB. I think you mean "ballx" and "bally". Also, you have a line... ifjoy0fire then ...you need a space after the "if" and some actual code needs to follow the "then" Quote Link to comment Share on other sites More sharing options...
esplonky Posted July 17, 2011 Author Share Posted July 17, 2011 i accidentally forgot to delete the ifjoy0fire then, because i didn't need it Quote Link to comment Share on other sites More sharing options...
esplonky Posted July 17, 2011 Author Share Posted July 17, 2011 i fixed those two errors and now i get this error when i try to compile: [root@Esplonky pong]# make 2600basic.sh default.bas -O Starting build of default.bas 2600 Basic compilation complete. DASM V2.20.09, Macro Assembler ©1988-2003 bytes of ROM space left 2476 bytes of ROM space left 2476 bytes of ROM space left --- Unresolved Symbol List pfcenter 0000 ???? (R ) 0.knock_player_back 0000 ???? (R ) ball0y 0000 ???? (R ) kernelmacrodef 0000 ???? (R ) pfhalfwidth 0000 ???? (R ) Fatal assembly error: Source is not resolvable. Build complete. \n > > > Compile of default.bas FAILED! > > >\n Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted July 17, 2011 Share Posted July 17, 2011 Instead of pulling bits and pieces out of an example program and creating a mangled mess, you might want to start with the example program and make little changes here and there. When one little change works, you can make another little change and so on until you have what you want. Quote Link to comment Share on other sites More sharing options...
ScumSoft Posted July 17, 2011 Share Posted July 17, 2011 Also I think it doesn't like double underscores in labels Quote Link to comment Share on other sites More sharing options...
RevEng Posted July 17, 2011 Share Posted July 17, 2011 i fixed those two errors and now i get this error when i try to compile: ... --- Unresolved Symbol List pfcenter 0000 ???? (R ) 0.knock_player_back 0000 ???? (R ) ball0y 0000 ???? (R ) ... You still have a ball0y in there somewhere. Quote Link to comment Share on other sites More sharing options...
