Roydea6 Posted August 2, 2011 Share Posted August 2, 2011 (edited) Here is one that is hacked for the H: option in the emulator. Who has done the hack and is there any chance for further improvements? GOTO: http://www.atariage....ost__p__1804539 by Fandal maybe reply to his post about info for further impro's. Edited August 2, 2011 by rdea6 Quote Link to comment Share on other sites More sharing options...
rost Posted August 3, 2011 Share Posted August 3, 2011 Thanks for the link. I'll keep that at the back of my mind, but at the moment, i don't want to bother fandal with it... Quote Link to comment Share on other sites More sharing options...
Shamus Posted August 3, 2011 Share Posted August 3, 2011 If you look at this post: http://www.atariage.com/forums/topic/130910-latest-additions-to-atarimania-database/page__view__findpost__p__1864615 you'll see my dumps of my own OSS carts, including Action! If the Action! cart is built in the wrong order, I'd appreciate knowing so I can fix it. Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted August 3, 2011 Share Posted August 3, 2011 If you look at this post: http://www.atariage....ost__p__1864615 you'll see my dumps of my own OSS carts, including Action! If the Action! cart is built in the wrong order, I'd appreciate knowing so I can fix it. It's fine. Interesting. Your dump differs from mine by just one byte. They are both Action! ver. 3.6. Quote Link to comment Share on other sites More sharing options...
russg Posted August 4, 2011 Author Share Posted August 4, 2011 (edited) If you look at this post: http://www.atariage....ost__p__1864615 you'll see my dumps of my own OSS carts, including Action! If the Action! cart is built in the wrong order, I'd appreciate knowing so I can fix it. It's fine. Interesting. Your dump differs from mine by just one byte. They are both Action! ver. 3.6. I responded to the original Oct. '09 post by Shamus of his ACTION!.A8 dump. That dump has a 16 byte header, starting with 'CART' that shouldn't be there. And the order of banks is 0 1 9 M, it should be M 0 9 1 for a B cart, at least that's my black/yellow cart and PUL's .ROM file. I didn't check to see if the ACTION!.A8 runs OK in A8WINPLUS 4 or ALTIRRA 1.9. Maybe it does. Does it (ACTION!.A8) run in an emulator? Edit: Yep, it runs in A800WINPLUS 4, but not Altirra 1.9 Edited August 4, 2011 by russg Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted August 4, 2011 Share Posted August 4, 2011 If you look at this post: http://www.atariage....ost__p__1864615 you'll see my dumps of my own OSS carts, including Action! If the Action! cart is built in the wrong order, I'd appreciate knowing so I can fix it. It's fine. Interesting. Your dump differs from mine by just one byte. They are both Action! ver. 3.6. I responded to the original Oct. '09 post by Shamus of his ACTION!.A8 dump. That dump has a 16 byte header, starting with 'CART' that shouldn't be there. And the order of banks is 0 1 9 M, it should be M 0 9 1 for a B cart, at least that's my black/yellow cart and PUL's .ROM file. I didn't check to see if the ACTION!.A8 runs OK in A8WINPLUS 4 or ALTIRRA 1.9. Maybe it does. Does it (ACTION!.A8) run in an emulator? Edit: Yep, it runs in A800WINPLUS 4, but not Altirra 1.9 I removed the header before testing or comparing. Atari800 2.2.1 accepts Shamus' image as an 034M cart (or whatever the real order turns out to be) just as it does my image. No problems in Altirra either but I'm using 2.00-test14 because I was wanting to try out SIDE and MyIDE emulations -Steve Sheppard 2 Quote Link to comment Share on other sites More sharing options...
