Dylanrohl Posted August 4, 2011 Share Posted August 4, 2011 This is probably super easy for people who are good with this kind of stuff, but when I try to play my game to test if the code was right, it gives me this message: "[8/3/2011 5:26:25 PM] Could not locate default.bas.bin. Attempting recompile..." A message also appears saying "could not locate default.bas.bin and could not recompile. Please check to make sure it was compiled correctly. Any help would be greatly appreciated. -Dylan Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 4, 2011 Share Posted August 4, 2011 See if this helps: http://www.randomterrain.com/atari-2600-memories-batari-basic-vbb.html#install_vbb Quote Link to comment Share on other sites More sharing options...
jwierer Posted August 4, 2011 Share Posted August 4, 2011 This is probably super easy for people who are good with this kind of stuff, but when I try to play my game to test if the code was right, it gives me this message: "[8/3/2011 5:26:25 PM] Could not locate default.bas.bin. Attempting recompile..." A message also appears saying "could not locate default.bas.bin and could not recompile. Please check to make sure it was compiled correctly. Any help would be greatly appreciated. -Dylan The problem isi usally the setup for bB which is failing to create a binary in the first place. I would use steps on RT's site so you're using the latest compiler release along with the modified .bat file. Should fix the problem with valid code not compiling. Then again it could just be that your code isn't compiling because of a syntax error. -Jeff Quote Link to comment Share on other sites More sharing options...
