José Pereira Posted August 17, 2011 Share Posted August 17, 2011 (edited) Hex. Decimal Instruction 0 0 Leave 1 blank display line 10 16 Leave 2 blank display lines 20 32 Leave 3 blank display lines 30 48 Leave 4 blank display lines 40 64 Leave 5 blank display lines 50 80 Leave 6 blank display lines 60 96 Leave 7 blank display lines 70 112 Leave 8 blank display lines 2 2 Display as GRAPHICS 0 text mode 3 3 Display as special text mode 4 4 Display as 4-color text mode 5 5 Display as large 4-color text mode 6 6 Display as GRAPHICS 1 text mode 7 7 Display as GRAPHICS 2 text mode 8 8 Display as GRAPHICS 3 4-color graphic mode 9 9 Display as GRAPHICS 4 2-color graphic mode A 10 Display as GRAPHICS 5 4-color graphic mode B 11 Display as GRAPHICS 6 2-color graphic mode C 12 Display as special 160x20, 2-color graphic mode D 13 Display as GRAPHICS 7 4-color graphic mode E 14 Display as special 160x40, 4-color graphic mode F 15 Display as GRAPHICS 8, 1 1/2 color graphic mode 1 1 Jump to location specified by next two bytes 41 65 Jump to location specified by next two bytes and wait for vertical blank What is that value 3 that says 'SPECIAL TEXT MODE'? Edited August 17, 2011 by José Pereira Quote Link to comment Share on other sites More sharing options...
+Stephen Posted August 17, 2011 Share Posted August 17, 2011 I believe that is the 10-line true descender mode. See this ANTIC article. Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted August 17, 2011 Share Posted August 17, 2011 I recently discovered this mode - Antic 3 - and its descenders ability. Note the lower case g and y for an example of the descenders part of a letter. Quote Link to comment Share on other sites More sharing options...
Alphasys Posted August 18, 2011 Share Posted August 18, 2011 Yep, Mode 3 is the descender mode. It is 10 scanlines high, but still uses the 8x8 char matrix. The lower case letters are setup so that the "descender" is actually the top byte of the char. If the lower case "g" is setup as: ..XXXX.. ........ ........ ..XXXXX. .XX..XX. .XX..XX. ..XXXXX. .....XX. It will actually display in mode 3 as: ........ ........ ........ ..XXXXX. .XX..XX. .XX..XX. ..XXXXX. .....XX. ..XXXX.. ........ I'm not 100% sure about this, but I think only the lower case letters are affected in this way, but I could be mistaken. I'll have to investigate this in more depth, but maybe one here can already answer this. Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 18, 2011 Share Posted August 18, 2011 Top 2 bytes are used acutally. It affects any character with bits 5-6 = 11 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 18, 2011 Share Posted August 18, 2011 Top 2 bytes are used acutally. It affects any character with bits 5-6 = 11 If you do use this mode ... keep in mind that lowercase ascenders (that is, t, l, b, d, h, k) should be defined in a different range than the other lowercase characters ... stay away from atascii 0-32 and atascii>96 ... this will let your lowercase font look more unified. Lowercase letters in ANTIC 3 forbid the use of the top two rows of the char grid. Using this method you have your ascenders reaching to the top of the grid while your descenders lke g j q p etc. will reach to the bottom. ctrl chars will look strange in this mode too because of the reordering of the lowercase descenders. Quote Link to comment Share on other sites More sharing options...
phaeron Posted August 18, 2011 Share Posted August 18, 2011 Vertical reflect (CHACTL bit 2) also doesn't work properly with IR mode 3. It inverts A0-A2 of the font fetch address instead of the row counter, so the descenders don't flip. Quote Link to comment Share on other sites More sharing options...
