Bartsfam Posted August 21, 2011 Share Posted August 21, 2011 I searched for help, I really did, but I could not find the help I need to get past the freaking monkeys on Level 2 while swinging on the vines. They keep knocking me off the vines. What are you supposed to do? Aim for a spot where the monkey isn't? I don't have the manual, but I don't believe you can get higher or lower on the vine. How do you get by the monkeys on Level 2 vines? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted August 21, 2011 Share Posted August 21, 2011 I just jump over the monkey and everything is fine ... that work for me Quote Link to comment Share on other sites More sharing options...
Bartsfam Posted August 21, 2011 Author Share Posted August 21, 2011 Must be a timing thing. Every time I jump, I manage to run into the monkey.... Quote Link to comment Share on other sites More sharing options...
AtariBrian Posted August 21, 2011 Share Posted August 21, 2011 bartstam, there is a video on youtube made by waspspray. go check it out Quote Link to comment Share on other sites More sharing options...
ColecoDan Posted August 21, 2011 Share Posted August 21, 2011 You have to be patient, if you sit there on the vine before the monkey you will see the monkey climb up and down the vine. When the monkey climbs up the vine then you can jump to the bottom of that vine. It is a pain though so I understand the frustration. It took me a while before I sat there trying to figure out what to do and then I saw the monkey start climbing up the vine. Quote Link to comment Share on other sites More sharing options...
