Zzalg_Repus Posted August 22, 2011 Share Posted August 22, 2011 Hello there! I'm using a SIO2SD interface with firmware V2.4_07 which I'd like to update. However, upon pressing Shift+K3 in setup mode nothing happens. Any help? Thanks, Zz Quote Link to comment Share on other sites More sharing options...
kheffington Posted August 23, 2011 Share Posted August 23, 2011 (edited) Hello there! I'm using a SIO2SD interface with firmware V2.4_07 which I'd like to update. However, upon pressing Shift+K3 in setup mode nothing happens. Any help? Thanks, Zz Not 100% sure but I think the key combo is Shift+K2 not K3 at least it was in some versions. Edited August 23, 2011 by kheffington Quote Link to comment Share on other sites More sharing options...
sloopy Posted August 23, 2011 Share Posted August 23, 2011 you have the firmware in the root directory, and an ATARI folder there also? here it says 2.x+ is shift+K3 i always thought it would automagically update, i dunno, i have a AVR ISP cable, so i never did a self update... sloopy. Quote Link to comment Share on other sites More sharing options...
kheffington Posted August 23, 2011 Share Posted August 23, 2011 (edited) Just tried it and the only way I could get it to upgrade was to hold down the shift on the SIO2SD while powering up the Atari and having it enter into configuration mode then hitting shift/K3 with sio2sd.bin in root of card. With the 2 version it the K4 held at start up may get it to configuration mode instead of the shift key. Don't know if that is the correct way but it worked. Edited August 23, 2011 by kheffington Quote Link to comment Share on other sites More sharing options...
w1k Posted August 23, 2011 Share Posted August 23, 2011 Boot atari, hold only shift key, 5sec Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 23, 2011 Author Share Posted August 23, 2011 Thanks for your replies, everyone. Unfortunately, none of them did the trick. Any new ideas? I'm a bit stumped here, because I used to upgrade my SIO2SD all the time. I'm no newbie to this. Quote Link to comment Share on other sites More sharing options...
w1k Posted August 23, 2011 Share Posted August 23, 2011 Then.. try hold 5s each key, if nothing, try hold shift with each key Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 23, 2011 Share Posted August 23, 2011 Thanks for your replies, everyone. Unfortunately, none of them did the trick. Any new ideas? I'm a bit stumped here, because I used to upgrade my SIO2SD all the time. I'm no newbie to this. Can you still boot ATR's from this? Do the buttons still allow you to assign ATR's to different drives? What does the display look like? Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 24, 2011 Author Share Posted August 24, 2011 Can you still boot ATR's from this? Do the buttons still allow you to assign ATR's to different drives? What does the display look like? Everything else works perfectly. Mounting and booting ATRs, the in-build loader for ATRs, setting different speeds etc. The display is fine. Just the upgrade won't do. Quote Link to comment Share on other sites More sharing options...
UKRetrogamer Posted August 24, 2011 Share Posted August 24, 2011 I had the same problem upgrading to v2.5. In the end, I worked out I'd not renamed the .bin file and had just downloaded it straight onto the card, leaving the original name intact. I'd need to check but the file name of the firmware needs to be something like sio2sd.bin. The upgrade process looks specifically for a .bin file with this name. If you've done the same as I did, you'll need to rename the file before the existing firmware will know it's there! Quote Link to comment Share on other sites More sharing options...
w1k Posted August 25, 2011 Share Posted August 25, 2011 hm, try ask pajero - http://www.atari.org.pl/forum/viewtopic.php?id=8671 Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 25, 2011 Author Share Posted August 25, 2011 (edited) Hi again! So, I finally *did* manage to get the upgrade working, just by overwriting the old sio2sd.bin file with a newer version. I did this before, but only now the upgrade actually did work. But... now the LCD display sometimes messes up, I get "card init errors" most, if not all of the time - just got my SD card working once so far. And oh, the built-in file selector won't work as well - or is there any difference in 3.0? Any help, please? Thanks, Frank Edited August 25, 2011 by Zzalg_Repus Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 25, 2011 Author Share Posted August 25, 2011 (edited) Ok, me again. Hello. So I'd like to revert back from buggy 3.0 to 2.5, but no. It's either "card init error" or, using a different SD card - recognised with 3.0 - "firmware update not available" - though the sio2sd.bin (v2.5) is in the root directory. Oh dear, I regret the day I thought of "upgrading" my SIO2SD device might be a good idea. So, in a nutshell, how do I go back from 3.0 to 2.5? (Wait a minute! "Back from 3.0 to 2.5"... Now, this does ring a bell, doesn't it. History repeats itself... *lol*) UPDATE: Why, you little...?! You're not gonne believe this: suddenly my regular SD card was on the go again, even the downgrade to 2.5 worked - only to produce a permanent "card i/o error - format fatxx". Now, what does this mean? The card I've been using for years now had been formatted in FAT, no hassle for all those years. Now everything went haywire. Will give up now and put the Atari back on its shelf. For now. Edited August 25, 2011 by Zzalg_Repus Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 25, 2011 Share Posted August 25, 2011 On the SD Card's root directory, you'll see the "SIO2SD.CFG" file. Rename it to "SIO_2SD.CFG" (too keep as a reference or just delete). Then pop the SD Card back into the Sio2SD and boot your A8... Jay Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 26, 2011 Author Share Posted August 26, 2011 On the SD Card's root directory, you'll see the "SIO2SD.CFG" file. Rename it to "SIO_2SD.CFG" (too keep as a reference or just delete). Then pop the SD Card back into the Sio2SD and boot your A8... That's it. Thanks a lot, Jay! Now, does anyone have a recommendation as to which firmware version to use? The latest 3.0 seems a bit buggy. Quote Link to comment Share on other sites More sharing options...
sloopy Posted August 26, 2011 Share Posted August 26, 2011 3.0 is so different from 2.x for me, i thought it was flakey at first, but then i realized i needed to RTFM... then went back to 2.x cause i was comfy with it... sloopy. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 26, 2011 Share Posted August 26, 2011 Same here. I had 3.x flashed on mine, but found that it wouldn't work on the 800, so I had to revert back to 2.5... Jay Quote Link to comment Share on other sites More sharing options...
+Philsan Posted August 26, 2011 Share Posted August 26, 2011 I had issues with IDE+ 2.0, so I downgraded to firmware 2.5. For sure I prefer loader v2.5 (but you can use it with firmware 3.0 too) because of its fast selection system. My video shows the case of a file in 37th position. Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 26, 2011 Author Share Posted August 26, 2011 For sure I prefer loader v2.5 (but you can use it with firmware 3.0 too) because of its fast selection system. What's missing, though, is to go backwards within a directory, <SPACE> only produces the next batch of files, but you can't go back. Quote Link to comment Share on other sites More sharing options...
Zzalg_Repus Posted August 26, 2011 Author Share Posted August 26, 2011 3.0 is so different from 2.x for me, i thought it was flakey at first, but then i realized i needed to RTFM... then went back to 2.x cause i was comfy with it... Is there a manual for 3.0? Here it says: "not updated for version 3.0 - please wait for update" Quote Link to comment Share on other sites More sharing options...
BigBen Posted August 27, 2011 Share Posted August 27, 2011 Hi Zzalg_Repus, if you can read german, look here: http://www.abbuc.de/phpBB3/viewtopic.php?f=15&t=5954 BigBen Quote Link to comment Share on other sites More sharing options...
