+bob1200xl Posted August 29, 2011 Share Posted August 29, 2011 I have some machine language routines that I want to convert to BASIC DATA statements. Isn't there a BASIC program out there that you can point at some object code and have it generate DATA statements that you can then ENTER into your program? I don't want strings because they are impossible to change easily and I have a ton of memory, anyway. Bob Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 29, 2011 Share Posted August 29, 2011 (edited) I did a handy utility called "HexPoke" decades ago, but I don't know if I've still got it. It allowed DATA with hex numbers and had a routine around 80 bytes or so that stored it into RAM. As for creating DATA from a file, it's something that's so simple that I don't bother keeping a program on hand. There's 2 ways - either generate a file then ENTER it, or use the "Forced E: input" method to generate the lines as part of the current program. So, all you need for method 1 is something like: 10 OPEN #1,4,0,"D:object.OBJ" 20 OPEN #2,8,0,"D:basic.LST" 30 LN=20000:REM Starting line # 40 TRAP 500 100 ? #2;LN;" DATA "; 110 GET #1,D:? #1;D; 120 FOR A=1 TO 19:GET #1,D:? #2;",";D; 130 NEXT A:? #2 190 LN=LN+10:GOTO 100 500 ? #2 510 CLOSE #1:CLOSE #2 If dealing with a Binary file, then just put a line after the OPEN that dummy-reads the first 6 bytes. Edited August 29, 2011 by Rybags Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 29, 2011 Author Share Posted August 29, 2011 Ohhh... well, that looks pretty simple. Heck, I'm a hardware guy, not a programmer. I never would have figured that out. Thanks! - saves me a lot of typing and converting. Bob I did a handy utility called "HexPoke" decades ago, but I don't know if I've still got it. It allowed DATA with hex numbers and had a routine around 80 bytes or so that stored it into RAM. As for creating DATA from a file, it's something that's so simple that I don't bother keeping a program on hand. There's 2 ways - either generate a file then ENTER it, or use the "Forced E: input" method to generate the lines as part of the current program. So, all you need for method 1 is something like: 10 OPEN #1,4,0,"D:object.OBJ" 20 OPEN #2,8,0,"D:basic.LST" 30 LN=20000:REM Starting line # 40 TRAP 500 100 ? #2;LN;" DATA "; 110 GET #1,D:? #1;D; 120 FOR A=1 TO 19:GET #1,D:? #2;",";D; 130 NEXT A:? #2 190 LN=LN+10:GOTO 100 500 ? #2 510 CLOSE #1:CLOSE #2 If dealing with a Binary file, then just put a line after the OPEN that dummy-reads the first 6 bytes. Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted August 29, 2011 Share Posted August 29, 2011 I have a program called Convert.bas which will convert any file, ML, Picture, Font, into either DATA statements or string assignments. The thread is here: http://www.atariage.com/forums/topic/147473-basic-program-fonts-wanted-in-string-format/page__p__1813361__fromsearch__1?do=findComment&comment=1813361 It will even strip out the first 6 bytes. If you use strings, there is a string offset into the variable name table which will immediately move the data into the location you want (a block POKE). Quote Link to comment Share on other sites More sharing options...
russg Posted August 30, 2011 Share Posted August 30, 2011 (edited) I have some machine language routines that I want to convert to BASIC DATA statements. Isn't there a BASIC program out there that you can point at some object code and have it generate DATA statements that you can then ENTER into your program? I don't want strings because they are impossible to change easily and I have a ton of memory, anyway. Bob Don't forget there are a few things to know about BASIC USR calls. X=USR(1536) BASIC pushes the return address on the stack, it also pushes the number of paramaters (X=USR(1536,16,32), one byte, then the parameter gets pushed LO first HI second. So there's at least one PLA (104) you put before your ML numbers. The return address shouldn't be PLAed off, it is needed for the RTS you put in your machine code. So the stack looks like this, one parameter passed: The order you pull off the stack (PLA) # of parameters (can be 0), one byte parameter HI byte parameter LO byte Return HI I think Return LO I think (could be LO HI, which is the usual. You PLA off the stack in the reverse of the way it is pushed, Called a first in last out stack (FILO).... no a LIFO stack, same thing. Edited August 30, 2011 by russg Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 30, 2011 Author Share Posted August 30, 2011 yes,,, whatever you said. I just PLA and RTS back. Bob I have some machine language routines that I want to convert to BASIC DATA statements. Isn't there a BASIC program out there that you can point at some object code and have it generate DATA statements that you can then ENTER into your program? I don't want strings because they are impossible to change easily and I have a ton of memory, anyway. Bob Don't forget there are a few things to know about BASIC USR calls. X=USR(1536) BASIC pushes the return address on the stack, it also pushes the number of paramaters (X=USR(1536,16,32), one byte, then the parameter gets pushed LO first HI second. So there's at least one PLA (104) you put before your ML numbers. The return address shouldn't be PLAed off, it is needed for the RTS you put in your machine code. So the stack looks like this, one parameter passed: The order you pull off the stack (PLA) # of parameters (can be 0), one byte parameter HI byte parameter LO byte Return HI I think Return LO I think (could be LO HI, which is the usual. You PLA off the stack in the reverse of the way it is pushed, Called a first in last out stack (FILO).... no a LIFO stack, same thing. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 30, 2011 Author Share Posted August 30, 2011 Got it - thanks! Bob I have a program called Convert.bas which will convert any file, ML, Picture, Font, into either DATA statements or string assignments. The thread is here: http://www.atariage.com/forums/topic/147473-basic-program-fonts-wanted-in-string-format/page__p__1813361__fromsearch__1?do=findComment&comment=1813361 It will even strip out the first 6 bytes. If you use strings, there is a string offset into the variable name table which will immediately move the data into the location you want (a block POKE). Quote Link to comment Share on other sites More sharing options...
