NIAD Posted September 27, 2011 Share Posted September 27, 2011 Turbo requires the Expansion Module #2 Driving Controller, this controller plugs into Joystick Port #1 in place of the Hand Controller. Then you place the Hand Controller plugged into Port #2 in the opening next to the steering wheel. The wheel controls your car's left and right movement while the hand controller is used to select the skill level via the numpad and is used to shift gears (hi and low). Also, there is a gas pedal that comes with the unit that is used to control your speed. While the Cabbage Patch Kids cart could be bad, your system might need to be opened up and cleaned up.... especially the Power Switch. See some of the recent threads concerning DIY options or contact Yurkie to inquire about his tremendous service. Quote Link to comment Share on other sites More sharing options...
IsaacSCheves Posted September 27, 2011 Author Share Posted September 27, 2011 so i cant use the Turbo game with a regular controller? so maybe my controllers do work fine???, ill just have to get some more games! i have had the case on unit opened myself i just used some caned air and blew everything out. but the turbo game comes on and i can press the fire button and the car will move i just cant steer it. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted October 3, 2011 Share Posted October 3, 2011 hook an atari,master system or genesis controller in port 1 and see if you can steer. use 2nd controller to press 1 to start. Quote Link to comment Share on other sites More sharing options...
ColecoFan1981 Posted October 4, 2011 Share Posted October 4, 2011 so i cant use the Turbo game with a regular controller? so maybe my controllers do work fine???, ill just have to get some more games! i have had the case on unit opened myself i just used some caned air and blew everything out. but the turbo game comes on and i can press the fire button and the car will move i just cant steer it. Yes, Turbo requires the Driving Module (Expansion Module #2). For now you may want to look for Donkey Kong. ~Ben Quote Link to comment Share on other sites More sharing options...
IsaacSCheves Posted October 4, 2011 Author Share Posted October 4, 2011 For now you may want to look for Donkey Kong. what do you mean look for donkey kong, what does that game have to do with it? Quote Link to comment Share on other sites More sharing options...
NIAD Posted October 4, 2011 Share Posted October 4, 2011 For now you may want to look for Donkey Kong. what do you mean look for donkey kong, what does that game have to do with it? Think he means just look for a cheap cartridge to buy so that you have another game to test the system and controllers with... especially if where ever you buy the cart(s) has tested and verified that they are in working order. Quote Link to comment Share on other sites More sharing options...
NIAD Posted October 4, 2011 Share Posted October 4, 2011 Plus, as you follow this forum, you will realize that ColecoFan1981 is a BIG Donkey Kong fan! Quote Link to comment Share on other sites More sharing options...
