SlowCoder Posted September 20, 2011 Share Posted September 20, 2011 I'm not new to coding. I understand command structure and procedure, and I programmed in BASIC for years. So batari Basic almost comes in 2nd nature to me. Right now I'm just goofing, learning the batari system. - I understand that the resolution is supposed to be 88 (V) x 159 (H). Why, when I set the ship at the supposedly center coordinates (44x80) it isn't centered? - I'll admit I haven't read through the entire documentation for batari (I'm not much of a manual reader), and that's probably why I'm a little confused about my next question ... From what I can tell, there are 2 sprites, player 1, and player 2. How do games like Space Invaders (6x6 invaders, 3 shields, and the player cannon) manage so many sprites on the screen at one time? At first guess, I'd think maybe just swapping sprites between each iteration of drawscreen, but if that was the case, each sprite would only get drawn 2 times a second (if I'm understanding things right), which would make hellish flicker. So how is this accomplished? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 20, 2011 Share Posted September 20, 2011 All kinds of magic can be done with assembly language. You might want to read Racing the Beam: http://www.amazon.com/gp/product/026201257X/ref=as_li_ss_tl?ie=UTF8&tag=atariage&linkCode=as2&camp=217145&creative=399369&creativeASIN=026201257X You might also want to watch this video: http://www.youtube.com/watch?v=MBT1OK6VAIU&rel=0&fmt=35 batari Basic is amazing because it lets average people who only know BASIC style languages get the beginnings of a game up on the screen in minutes instead of days or months. The speed and ease of use come at a cost, though. There are a lot of things we can't do, but those limitations are shrinking. For example, the DPC+ beta version of bB lets us have 10 multicolored sprites on the screen at the same time. 1 Quote Link to comment Share on other sites More sharing options...
SlowCoder Posted September 21, 2011 Author Share Posted September 21, 2011 I found that video to be quite interesting to watch. While he didn't go into really great detail on game design, I got a good feel for what went into the process. Thank you for that link. I will take a look at the ASM. Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 21, 2011 Share Posted September 21, 2011 - I understand that the resolution is supposed to be 88 (V) x 159 (H). Why, when I set the ship at the supposedly center coordinates (44x80) it isn't centered? bB follows the usual convention, where the X/horizontal coordinate to go first, then the Y/vertical coordinate. If you set your ship to 80,44 it will be approximately centered. The coordinate actually locates the left+top corner of the player. From what I can tell, there are 2 sprites, player 1, and player 2. How do games like Space Invaders (6x6 invaders, 3 shields, and the player cannon) manage so many sprites on the screen at one time? At first guess, I'd think maybe just swapping sprites between each iteration of drawscreen, but if that was the case, each sprite would only get drawn 2 times a second (if I'm understanding things right), which would make hellish flicker. So how is this accomplished? One method is flickering, as you indicate. Pacman uses this technique. Another is to enable a register that creates 1 or 2 copies of a player beside the regular one. Combat uses this one, in the modes where there are 3 planes side by side. As RT alludes, if you write your own display kernel you can also reuse these same players in different horizontal sections of the screen, like Pitfall, Keystone Kapers, and many others. You can also have your custom kernel strobe the reset registers, like galaxian does. Lots of techniques, lots to learn. If you're ready for asm, check out Andrew Davie's Tutorials and the Stella Programming Guide. Quote Link to comment Share on other sites More sharing options...
esplonky Posted September 21, 2011 Share Posted September 21, 2011 If you are watching Tinkernut's video... good luck. he is wrong about some things. Quote Link to comment Share on other sites More sharing options...
