5200 Collector Dude Posted October 5, 2011 Share Posted October 5, 2011 I got a 5200 vcs adapter and it works.However,the fire button on all my controllers doesn't work with it.It goes in all directions and works,but the fire button doesn't. Please help! Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted October 5, 2011 Share Posted October 5, 2011 Well if none of your controllers work with it (I assume they work on other systems) just a shot in the dark, are any of the port pins on the VCS adapter pushed in? Or worse yet missing or any type of problem? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 5, 2011 Share Posted October 5, 2011 Check with a meter for continuity from each pin in the port to the 1st point they end up on the board away from the port itself. Quote Link to comment Share on other sites More sharing options...
Curt Vendel Posted October 5, 2011 Share Posted October 5, 2011 Its either a bad solder joint on the control port or one of the inputs on the RIOT is hosed and you'll need to replace the 6532.... more then likely it may just be a bad connection at the joystick port. Quote Link to comment Share on other sites More sharing options...
5200 Collector Dude Posted October 6, 2011 Author Share Posted October 6, 2011 None seem to be pushed in,I'll try the second controller port soon and see if it has the same problem. Quote Link to comment Share on other sites More sharing options...
