Chris Union NJ Posted October 23, 2011 Share Posted October 23, 2011 Are there any NTSC software sites out there or a site with NTSC patchs? Chris Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 23, 2011 Share Posted October 23, 2011 Are there any NTSC software sites out there or a site with NTSC patchs? Chris Not really. However with your SC1224 you shouldn't need to worry. The monitor and ST work as PAL with no issues. They say there are a few things that require a PAL ST but those are mostly demos and Ive not met a game that didnt switch the ST to the mode it wants and run fine. Quote Link to comment Share on other sites More sharing options...
Chris Union NJ Posted October 23, 2011 Author Share Posted October 23, 2011 Are there any NTSC software sites out there or a site with NTSC patchs? Chris Not really. However with your SC1224 you shouldn't need to worry. The monitor and ST work as PAL with no issues. They say there are a few things that require a PAL ST but those are mostly demos and Ive not met a game that didnt switch the ST to the mode it wants and run fine. I took the monitor roll on only some of the games as a pal problem since i'm use to this on the amiga I thought it might be the same on the ST. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 23, 2011 Share Posted October 23, 2011 (edited) Are there any NTSC software sites out there or a site with NTSC patchs? Chris Not really. However with your SC1224 you shouldn't need to worry. The monitor and ST work as PAL with no issues. They say there are a few things that require a PAL ST but those are mostly demos and Ive not met a game that didnt switch the ST to the mode it wants and run fine. I took the monitor roll on only some of the games as a pal problem since i'm use to this on the amiga I thought it might be the same on the ST. There is V hold on the back of the monitor. If it rolls in PAL, get it to do it again and turn the v hold adjustment until it stops rolling. Just be gentle. Don't press in too hard with the screw driver. It is very easy to bend those adjustment pots right down until they lay almost flat on the board! Edited October 23, 2011 by Official Ninja Quote Link to comment Share on other sites More sharing options...
Chris Union NJ Posted October 24, 2011 Author Share Posted October 24, 2011 (edited) Are there any NTSC software sites out there or a site with NTSC patchs? Chris Not really. However with your SC1224 you shouldn't need to worry. The monitor and ST work as PAL with no issues. They say there are a few things that require a PAL ST but those are mostly demos and Ive not met a game that didnt switch the ST to the mode it wants and run fine. I took the monitor roll on only some of the games as a pal problem since i'm use to this on the amiga I thought it might be the same on the ST. There is V hold on the back of the monitor. If it rolls in PAL, get it to do it again and turn the v hold adjustment until it stops rolling. Just be gentle. Don't press in too hard with the screw driver. It is very easy to bend those adjustment pots right down until they lay almost flat on the board! Yep that did it thanks now playing Pang!! And does not effect the other stuff that worked.. Chris Edited October 24, 2011 by Chris Union NJ Quote Link to comment Share on other sites More sharing options...
