+JAC! Posted October 24, 2011 Share Posted October 24, 2011 Hi there, I have a large project which is almost finished now, dead line is next week, so I started testing on real hardware using my Harmony cart. On my first (very old) TV set, everything is fine. On my (old) TV set, the screen loses sync at the beginning. Stella shows 50 Hz/312 Scanlines/PAL and I have no clue, what could be wrong. The later parts all work fine. I have attached version which simply loops the intro. So maybe somebody can test it on his real PAL machine, too or maybe even find out what "magic thing" goes wrong here. Rolling.bin Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 25, 2011 Share Posted October 25, 2011 Stepping through it in Stella, I'm seeing 3 lines of VSYNC, which is good, but VBLANK isn't ever turned on. VSYNC is the most critical, for sure, but it's my understanding that some TVs aren't happy without a real vertical blank. Quote Link to comment Share on other sites More sharing options...
+stephena Posted October 25, 2011 Share Posted October 25, 2011 Stepping through it in Stella, I'm seeing 3 lines of VSYNC, which is good, but VBLANK isn't ever turned on. VSYNC is the most critical, for sure, but it's my understanding that some TVs aren't happy without a real vertical blank. At some point I hope to add emulation for this to Stella (so that it acts more like a real TV, and rolls when appropriate). 1 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted October 27, 2011 Author Share Posted October 27, 2011 (edited) Great! It's what you get when you name a procedure like a system label (silly me). Looking at the list file, it is plain to see: 38 709F .proc vblank 39 709F A9 31 lda #49 ;(45-6)*76/64 = 46,3125 the logo requires 6 scanlines for object positioning 40 70A1 8D 96 02 sta tim64t 41 42 70A4 4C 41 70 jmp call_vblank ;Call routine pointed to by vblank_ptr in other bank 43 70A7 return 44 45 70A7 20 8E 7C jsr effect.logo.vblank ;Animate the logo 46 47 70AA AD 84 02 sync lda intim ;Sync with beam again 48 ; sta colubk ;Debug remaining time 76 70C7 A9 02 lda #2 ;<A>:=2 77 70C9 8D 9F 70 sta vblank ;Activate VBLANK bit 1 49 ;stop bmi stop ;Time overrun 50 70AD D0 FB bne sync 51 70AF 85 02 sta wsync 52 70B1 8D 9F 70 sta vblank ;Deactivate VBLANK bit 1 53 .endp BUT: Now that I set/reset VBLANK the situation on the TV gets completely out of control. Not only the screen is rolling (even more than before) but also the 2600 seems to reduce its speed during the rolling. The sound frequency drops and the speed of the effects is "slow motion". Crazy. It the kind of things that ONLY happed 3 days before the deadline... I think I simply got the timing wrong for re/setting VBLANK, so I hope some of you can also help here. Here is the exmaple file: ISO.bin Edited October 27, 2011 by JAC! Quote Link to comment Share on other sites More sharing options...
+JAC! Posted October 28, 2011 Author Share Posted October 28, 2011 Found 2 solution which works for this TV, I'll go any try some other TV set now. lda #$0e ;Create 3 lines of vsync=1 plus 1 line of vsync=0 sta :vblank ;Activate VBLANK bit 1 in scanline 308 vsync_loop sta wsync sta vsync lsr bne vsync_loop sta :vblank ;Deactivate VBLANK bit 1 in scanline 0 Quote Link to comment Share on other sites More sharing options...
