Rich BASIC2GPL Compiler
RXB
I have started work on a BASIC to GPL Compiler.
It uses the same REA (Editor Assembler) so other then XB and Assembler it is the same module.
Option 2 Assembler is replaced with COMPILER that takes BASIC list files and turns them into GPL Source files.
As they are GPL Source files you can edit the results before you use the GPL Assembler to turn them into OBJECT Code.
A XB version will include a utility to strip XB list files from Mulit statement to Single statement files for the Compiler to better work.
Yeah, that's interesting news! I think the compilers around until now all compile to assembly language and none to GPL.
I presume that with your profound background knowledge on both GPL and the (Extended) Basic interpreter you should be able to pull this of and make this a fun project.
:thumbsup: :thumbsup: :thumbsup:
It should be remarkably easy as BASIC and XB are written in GPL so not like I can not find the subroutine to pull it off.
Th next step from GPL should also be pretty easy to pull off as GPL is written in Assembly.
The last step would be to take the BASIC and make Assembly Compiler that should be remarkably accurate and easy to use.
Any project should be taken in steps to get a better project. The smaller the steps the better the project looks.
The only difficult thing I can think of is the evaluation of complex expressions:
X=INT(A*RND(B))+COS©/(ATN(Z)*PI+(32*(T-3/RND(F)))
You get the idea. You need to evaluate according to the order of precedence. You need stacks for that. :thumbsup:
I am going to include the standard floating point into the package so it is exactly the same as BASIC or XB so you can do this, but the trade off will still be that it slows the program down.
My goal is to do a straight across conversion from XB or BASIC to GPL. Then do the next step to go Assembly.
Not the first, as part of my MPD project I released an XB to GPL compiler: http://www.harmlesslion.com/software/gpl
it was pretty hacky and very limited, I only used it to make writing the configuration code easier, but I had intended to extend the project if it gathered any interest. It didn't, though, so I left it be. ;) It's written in C so runs on a PC to do the conversion. Full source is included.
Dunno if it'll be useful to you to take a peek at it or not, Rich, but you are welcome to borrow from it if anything is valuable to you!
Here is some the source code for XB to GPL Compiler.
Most are debugged but some I still need to work on. They are all Floating Point based just like XB.
Left side is the input after the name, after FPT is the output.
* PI (@FAC) FLP (@FAC)
PI MOVE 8,G@CONPI,@FAC
  RTN
CONPI BYTE >40,3.14,15,92,65,35,90
* MAX (@FAC,@ARG) FLP (@FAC)
MAX GT
   BR MAXO
MAXO MOVE 8,@ARG,@FAC
MAX1 RTN
* MIN (@FAC,@ARG) FLP (@FAC)
MIN GT
   BR MAXO
   RTN
* INTRND FLP
INTRND MOVE 10,G@X2SEED,V@RNDX2
   RTN
X2SEED BYTE >42,>03,>23,>15,>00
X1SEED BYTE >43,>02,>3E,>2A,>17
* RND (@FAC) FLP
RND MOVE 5,V@RNDX1,@FAC
   CLR @FAC5
   DCLR @FAC6
   XML VPUSH
   MOVE 8,G@RNDA1,@ARG
   XML FMUL
   MOVE 8,G@RNDC1,@ARG
   XML FADD
   XML VPUSH
   MOVE 8,G@RNDEM,@ARG
   XML MFUL
   CALL GRINT
   XML VPUSH
   MOVE 8,G@RNDEP,@ARG
   XML FMUL
   DSUB 8,@VSPTR
   XML SSUB
   MOVE 5,@FAC,V@RNDX1
   XML VPUSH
   MOVE 5,V@RNDX2,@FAC
   CLR  @FAC5
   DCLR @FAC6
   MOVE 8,G@RNDA1,@ARG
   XML FMUL
   DADD 8,@VSPTR
   XML VPUSH
   DSUB 24,@VSPTR
   XML VPOP
   DADD 32,@VSPTR
   MOVE 8,G@RNDA2,@ARG
   XML FMUL
   XML SADD
   MOVE 8,G@RNDA2,@ARG
   XML FADD
   XML SADD
   DSUB 16,@VSPTR
   XML VPUSH
   CALL GRINT
   MOVE 8,G@RNDEP,@ARG
   XML FMUL
   XML SSUB
   MOVE 5,@FAC,V@RNDX2
   MOVE 8,G@RNDEM,@ARG
   XML FMUL
   XML VPUSH
   DADD 8,@VSPTR
   XML VPOP
   XML FMUL
   XML FMUL
   XML SADD
   RTN
RNDA2 BYTE >43,>01,>2B,>59,>52,>00,>00,>00
RNDA1 BYTE >42,>2A,>08,>15,>00,>00,>00,>00
RNDC2 BYTE >43,>02,>0B,>20,>30,>00,>00,>00
RNDC1 BYTE >43,>06,>36,>05,>13,>00,>00,>00
RNDEP BYTE >43,>0A,>00,>00,>00,>00,>00,>00
RNDEM BYTE >3C,>0A,>00,>00,>00,>00,>00,>00
* RANDOM (@FAC) FLP
NRANDMZ DCZ @FAC
    BS  GA3B6
    ST  >46,@FAC
    XML VPUSH
    MOVE 8,G@RNDEM,@ARG
    XML FMUL
    CALL GRINT
    MOVE 5,@FAC,V@RNDX2
    MOVE 8,G@RNDEP,@ARG
    XML FMUL
    XML SSUB
    MOVE 5,@FAC,V@RNDX1
    RTN
GA3B6   DST  @FAC,V@RNDX2
    DST  @FAC,V@RNDX1
    RTN
RNDM1   DST  >4201,@FAC
    CLR  @FAC4
    CALL RNDMZ
    DATA RNDX1
    CALL RNDMZ
    DATA RNDX2
    RTN
RNDMZ   FETCH @FAC8
    FETCH @FAC9
    RAND  99
    ST    @RANDOM,@FAC2
    SRL   2,@FAC2
    RAND  99
    ST    @RANDOM,@FAC3
    SRL   2,@FAC3
    MOVE  5,@FAC,V*FAC8
    RTN
* SEG (@STRADD,@STRLEN,@FAC,ARG) (V*SREF)
SEG	 DST   @FAC,@ARG2
    DST   @ARG2,@TEMP2
    DCH   @STRLEN,@TEMP2
    BS    SEGZ08
    DADD  @ARG,@TEMP2
    DSUB  @STRLEN,@TEMP2
    DDEC  @TEMP2
    DCGE  0,@TEMP2
    BR    SEGZ06
    DST   @STRLEN,@ARG
    DSUB  @ARG2,@ARG
    DINC  @ARG
SEGZ06  DST   @ARG,@BYTES
    DST   @STRADD,@TEMP5
    DADD  @ARG2,@TEMP5
    DDEC  @TEMP5
    DST   @BYTES,@STRLEN
    MOVE  @BYTES,*TEMP5,V*SREF * TEMP STRING AREA
    RTN
SEGZ08  DCLR  @ARG
    BR    SEGZ06
* LEN (@STRADD) FLP (@FAC)
LEN	 DST   @STRLEN,@FAC
    XML   CIF
    RTN
* CHR (@FAC) FLP (@FAC)
CHR	 XML   FLTINT
    RTN
* ASC (@STRADD,@STRLEN) FLP (@FAC)
ASC	 DCZ   @STRLEN
    BS    ERRBA * ERROR BAD ARGUMENT
    ST    @STRADD,@FAC1
    CLR   @FAC
    XML   CIF
    RTN
* STR (@FAC,@STRADD) FLP (@STRADD)
STR	 CLR  @FAC11
    XML  CNS
    CEQ  SPACE,*FAC11
    BR   GA53E
    INC  @FAC11
    DEC  @FAC12
GA53E   CLR  @BYTES
    ST   @FAC12,@BYTES+1
    DCZ  @BYTES
    MOVE @BYTES,*FAC11,@STRADD
    DST  @BYTES,@STRLEN
    RTN
* VAL (@STRADD,@STRLEN) FLP (@FAC)
VAL	 DCZ  @STRLEN
    CALL VALCD
    RTN
VALCD   DST  @STRADD,@TEMP5
    DADD @STRLEN,@TEMP5
    DST  @STRLEN,@BYTES
    DINC @BYTES
GA57C   DDEC @TEMP5
    DDEC @BYTES
    BS   RTNSET
    CEQ  SPACE,*TEMP5
    BS   GA57C
    DINC @BYTES
    DST  @FAC4,@TEMP5
    CLR  @FAC8 * FORCE VDP MODE
    MOVE @BYTES,*TEMP5,v*SREF * SREF IS A STRING BUFFER IN VDP
    DADD @SREF,@BYTES
    DDEC @BYTES
    ST   SPACE,v*BYTES
    DST  @SREF,@FAC12
GA5A4  CEQ  SPACE,v*FAC12
    BR   GA5AE
    DINC @FAC12
    BR   GA5A4
GA5AE   CLR  @FAC2
    CLR  @FAC10
    XML  CSNUM
    DCEQ @BYTES,@FAC12
    BS   WRNNO * WARNING CHECK OVERFLOW
RTNSET  CEQ  @>8300,@>8300
    RTNC
* POS (@STRADD1,@STRADD2,@FAC) FLP (@FAC)
POS	 DCLR @FPERAD
    XML  FLTINT
    CZ   @FAC10
    BR   ERRBV * ERROR BAD VALUE
    CGE  0,@FAC
    DCZ  @FAC
    BS   ERRBV * ERROR BAD VALUE
    DST  @FAC,@BYTES
    DDEC @BYTES
    MOVE 8,@FAC,@ARG
    DCZ  @FAC7
    BS   POS12
    CH   @BYTES+1,@FAC7
    BR   POS12
    CZ   @ARG7
    BS   POS06
    DADD @BYTES,@FAC4
    SUB  @BYTES+1,@FAC7
POS02   CHE  @ARG7,@FAC7
    BR   POS12
    DST  @FAC4,@FAC
    DST  @ARG4,@ARG
    ST   @ARG7,@ARG8
    CEQ  *FAC,*ARG
    BR   POS10
    DINC @FAC
    DINC @ARG
    DEC  @ARG8
    BR   POS04
POS06   INC  @BYTES+1
POS08   DST  @BYTES,@FAC
    XML  CIF
    RTN
POS10   INC  @BYTES+1
    DEC  @FAC7
    DINC @FAC4
    BR   POS02
POS12   CLR  @BYTES+1
    BR   POS08
* RPT (@STRADD,@STRLEN,@FAC) FLP (V*SREF) TEMP VDP STRING
RPT	 DCLR @FPERAD
    XML  FLTINT
    CZ   @FAC10
    CGE  0,@FAC
    DCZ  @FAC
    BS   RPT1
    DCZ  @STRLEN
    BS   RPT1
    ST   @STRLEN+1,@ARG
    MUL  @FAC,@ARG
    CH   255,@ARG
    DST  @SREF,@ARG
RPT0   MOVE @STRLEN,@STRADD,V*ARG * VDP TEMP STRING
    DADD @STRLEN,@ARG
    DDEC @FAC
    BR   RPT0
RPT1   RTN
Working on two versions.
First is GPL Editor Assembler that takes DV80 listings of XB programs and turns them into DV 80 GPL Source.
Second is RXB XB program that takes DV 163 Merge format and creates a DV 80 GPL Source.
The XB version is moving much faster. Can do DIM like X(2,3,4) or Z$(3,4)
Can also do REM or ! and OPTION BASE so far. I am presently working on all DATA types statements.
I only see the DEF and OPEN commands as the real tough ones to convert as they have so many options.
Well ran into first snag. Here are the tokens in XB GPL Source:
*	  EQU  >C6			   spare token
STRINZ EQU  >C7			   QUOTED STRING
UNQSTZ EQU  >C8			   UNQUOTED STRING
NUMZ   EQU  >C8			   ALSO NUMERICAL STRING
LNZ    EQU  >C9			   LINE NUMBER CONSTANT
*	  EQU  >CA			   spare token
What TI should have done is NUMZ (numerical string) should have been >C6 so that the same >C8 would not be used for 3 different types.
  • 3 weeks later...
So to maintain speed in running programs my original BASIC to GPL compiler was using Floating Point so you could use commands like this:
100 FOR I=F TO L STEP S
120 NEXT I
This has the advantage to work if S=-9 or S=9, but is much slower as Floating point is really processor intensive on slowing speed.
So I have had to opt for not using Floating Point unless required. Thus:
100 FOR I=F TO L STEP -9
110 NEXT I
This means all steps if a variable must be positive and any negative must be specified as a number. The speed difference is incredible.
The BGPLCOMPILER was started on the 26th so on the 26th of this month I will post a video of the progress after 30 days.
Edited by RXB
120 NEXT I
110 NEXT I
I don't understand why you talk about floating point numbers when an integer is negative. Both +9 and -9 can be represented with a 16 bits integer value. No need to use the 64 bits floating point encoding.
No ?
Guillaume.
GPL uses integers just like Assembly so here is an example of code from my BASIC to GPL Compiler:
In GPL would be
L100 DST @F,@I
L100A BR $+2
110 NEXT I
In GPL would be:
L110 DSUB 9,@I
DCEQ @I,@L
BR L100A
If the example was:
Then S would be a problem as the Compiler can not determine before hand if the S is negative DSUB or Positive DADD.
The XB interpeter does this on the fly but a Complier has to know one way of the other or it just will not work.
Also the memory address >0000 to >FFFF Hexidecimal or 0 to 65535 so there are not negative address, you are thinking in XB not GPL or Assembly.
Edited by RXB
You can add a negative number with DADD, -9 is represented as >FFF7 with the format used: http://en.wikipedia.org/wiki/Two_complement
"I" is not an address, it's a counter. As a signed 16 bits integer, it can have values between -32768 and +32767.
You can add a negative number with DADD, -9 is represented as >FFF7 with the format used: http://en.wikipedia..../Two_complement
A twos complement is where you sacrifice the top most bit to use as a sign bit. So >FFF7 is -9 but your range is then limited to like you said -32768 to 32767.
So of course a computation must be made each time you do this, using Assembly to do this is faster with a XML from GPL then straight GPL.
Thus this is why almost all XB is Floating Point as the Assembly is faster at this then just twos complement in GPL.
The point of the BASIC to GPL compiler is to speed it up, not stay the same speed. What would be the point of staying almost the same speed?
You don't need to use DSUB or DADD. Just use DADD.
Think about it:
9 - 9 = 0
9 + -9 = 0
So, you don't need to worry about the sign (i.e. whether the number is +ve or -ve) - If you are doing a subtraction (like stepping the loop index down by -9) then you add -9. If the loop index is going upwards, then, again, it's just an add.
HTH
K will see if the Assembler will accept this, I was thinking straight through interpetation. You are right the GPL Assembler will do the Twos Complement.
What computation do you mean? I'm a little bit confused by that!
Respectfully, I don't think that can be true. Admittedly, I haven't ever tested it, but having just written a floating point library for TurboForth, I reckon that FP computations are at least 1000 times slower than normal integer based operations. Okay, there is an extra computational 'layer' to go through when in GPL, but integer math will always be an order of magnitude faster than floating-point, even if the floating-point is written in assembly and the integer math is written in GPL. Don't forget, on the 9900 integer math is performed by the processor itself. Floating point must be done in software. A DADD or a DSUB will eventually resolve down to a 9900 A or S instruction, whereas a floating-point operation is a number of multiplies and divides performed in a loop.
Ok so it does not work.
100 FOR X=-128 TO -12 STEP -7
110 ! PROGRAM HERE
120 NEXT X
Now the GPL code using what you said:
99/4 GPL-ASSEMBLER (Pass 1) correct								   PAGE 0001
Version 2.0 (Weiand 1985)	 Options : LCSFPF
[0001]				 GROM >6000
[0002]
[0003] A000		  X EQU >A000
[0004] 6000 BF,8F,1D L100 DST -128,@X
   6003 00,FF,80
[0005] 6006 05,60,09 L100A B $+3
[0006] 6009		  L110 * ! ROUTINE HERE.
[0007] 6009 A3,8F,1D L120 DADD -7,@X
   600C 00,FF,F9
[0008] 600F CB,8F,1D	  DCHE -12,@X
   6012 00,FF,F4
[0009] 6015 40,06		 BR L100A
[0010]
[0011]				    END
99/4 GPL-ASSEMBLER (Pass 1) correct								   PAGE 0002
So first pass >A000 is >FF80
Add the -7 to >A000 is >FFF9 equals >FF79
So that is larger then -12 is >FFF4 so next pass
Add the -7 to >A000 is >FFF9 equals >FF72 and that is less then -12 and the program is done. Way off.
The problem is there is no CLE or CLT in GPL only CH or CHE or CGE or CEQ so kind of screwed doing this way.
Thanks Willsy would be first pass in GPL as >FFF4 + >FFF9 equals >FFED and that is larger then -128 =>FF80 so ends in one pass.
(with out a CLE or CLT in GPL this is a real pain, Assembly has the tools for this that GPL does not.)
So again fails. This is why Floating Point is so much better as it also handles decimals and exponents plus negative numbers.
Thank you but the idea was not to have to use twos complement conversions every time I load a number. I wanted to just use 0 to 65535 and check if it was negative.
I will have to use something that combines twos complement and Floating Point instead though this will really cut into the speed.
Rich...
You don't need CLT or CLE. CLT is equivalent to C¬GE (compare not-GE). That is, if the result of a comparison is not "≥", then it must be "<". By the same token, CLE is equivalent to C¬GT. So, if you would do a BS if you had a CLT instruction, then do a BR after a CGE, etc.
...lee
